Which pass preamp for unbalanced in/out ?
Old 9th February 2005, 11:50 AM   #1
supernet is offline supernet  Europe
supernet's Avatar
Default Which pass preamp for unbalanced in/out ?
For driving unbalanced power amplifier, which of these preamps is better option? Sound quality is very important.
Aleph 1.7 or Aleph L
Thanx
Old 9th February 2005, 03:34 PM   #2
azira is offline azira  United States
What exactly is a passive preamp?
Basically it's an attenuator right? as in a potentiometer?
I suppose then that there are several very high quality stepped attenuators (the chipamp evangelists all use them). Or you could choose to go with a relay powered resistor ladder and then it's a matter of resistor quality.
Danny
Old 9th February 2005, 05:40 PM   #3
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Hello Supernet,
Personally I like the Aleph P for what you are trying to do. There has been a lot of discussion in the forum about using a BOSOZ or Aleph P verses a Passive preamp.
There is a wonderful warmth and romance to the sound when using one of the Pass active preamp circuits. If you use a balanced source and an unbalanced amp, you should expect great results.
Good luck,
-David
Old 9th February 2005, 06:02 PM   #4
eLarson is offline eLarson  United States
eLarson's Avatar
I don't know where "passive" came into the conversation. But I'm going to ignore the binary choice of the original question and recommend a BOSOZ.
You can delete the drain resistor and associated components on the non-inverting input's MOSFET since you are going to use a strictly single-ended in to single-ended out. Take the output from the other MOSFET's drain. And ground the inverting input.
Presto: signal goes in one side, comes out the other side noninverted.
Would a woodchuck bother to chuck MDF?
Old 9th February 2005, 06:44 PM   #5
Looks like I should just eat my words for lunch today.. I misinterpreted the title to mean passive instead of Pass. Sorry folks. Too much time reading the chipamp forum I guess.
Danny
Old 9th February 2005, 11:02 PM   #6
hifimaker's Avatar
Hi Azira,
Don't feel too bad.... The Aleph L is a passive Preamp until the attuenator is set to about 75%, then the active components kick in.
Most people who have an Aleph L use it as a passive preamp.
Here's a link to the L's description.
http://www.fullswing.com/passlabs/alephl.html
-David
Old 10th February 2005, 11:33 AM   #7
supernet's Avatar
Thanks for reply.
I was thinking that Aleph P 1,7 Susy concept will not work so good with unbalanced inputs and outputs as balanced. So my idea of Aleph L come in.
Anybody knows when X2 service manual will come? Mr. Pass said that it should come out to the end of last year. I am a little bit impatient
Old 11th February 2005, 08:46 PM   #8
hifimaker's Avatar
Hi Supernet,
I asked earlier about the X2 Service manual... Here's Nelson's reply. Essentially he is waiting for patient approval for the attuenator.
http://www.diyaudio.com/forums/showt...902&highlight=
-David
Which pass preamp for unbalanced in/out ?Hide this!Advertise here!
My unbalanced preamp problem Brouilly Tubes / Valves 6 19th April 2009 02:09 PM
Pass X2 Preamp jleaman Pass Labs 19 30th March 2005 12:57 AM
Balanced DAC to unbalanced preamp (passive) conversions Dr.H Chip Amps 6 20th December 2004 05:56 AM
Pass DIY preamp PCB? illenema Pass Labs 2 28th January 2004 08:59 PM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
