Old 9th August 2002, 03:12 PM   #11
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I always use teflon jackets on my wire, but read somwhere that no jacket is better. It's just too much hassle to take care of all those tweaks.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 9th August 2002, 06:44 PM   #12
The one and only
Nelson Pass's Avatar
Currently we use white Teflon coated wire with about 130
fine copper strands wound around a non-conductive center.
Old 10th August 2002, 04:12 AM   #13
diyAudio Moderator Emeritus
roddyama's Avatar
Mr. Pass,
I light of your article http://www.passlabs.com/pdf/spkrcabl.pdf, are there other technical reasons that you use the particular wire you described in your post?
If so, what are they?
Is this wire used for low level signals only, or do you use a larger gauge of the same configuration for PSU and output wiring?
Rodd Yamas***a
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
Which cable to use on Aleph internal wiring? Sony Pass Labs 4 25th May 2005 02:05 AM
Bal-Unbal-Bal Cable Wiring richie00boy Everything Else 3 3rd February 2005 11:08 AM
What cable for internal wiring? roibm Everything Else 11 27th November 2004 11:18 AM
Audio cable wiring ejmdiscos Parts 1 24th May 2004 10:10 PM
Page generated in 0.06750 seconds (68.70% PHP - 31.30% MySQL) with 11 queries
