Old 7th February 2005, 12:42 AM   #1
Jye is offline Jye  Australia
Jye's Avatar
Smile Aleph 5 Running (Pic)
Hello all...
Finally got the caps for my Aleph 5 and powered it up 9am Saturday morning. Surprise surprise no sparks flames or smoke. After a couple of minutes everything heated up evenly and I measured the following voltages:
LEFT R14 4.52V, R11 5.32V Z5 9.06V, C7 4.46V and the output resistors 0.629, 0.605 and 0.542V and DC offset 8.5mV.
Right R14 4.54V, R11 5.25V Z5 9.06V, C7 4.59V and the output resistors 0.603, 0.611 and 0.659V and DC offset 4.3mV. After 1 hour and 10 hours of play these values had not changed by more than 10mV.
Power supply is CRC with 30,000uF (Will be 40,000 when I get the final 2 caps from back order), 2 1 ohm resistors in parallel and 40,000uF per rail. The voltage before and after the resistors are 38.1 and 36.3V so I am thinking of increasing the resistance the bring the voltage down to 34V and to try and reduce a bit of the hum that you can hear from about 1m away, and reduce the temp since the thermal switches cut in twice (it probable didn't help that it was 35C over the weekend )
I wouldn’t like to comment on the sound yet as I have it running through a crappy pot I had lying around for some sort of volume control.
Finally but not least I would like to thank Mr Pass for this wonderful amp and Mark for his helpful website and PCB design and of course anyone who has answered my questions on this site
Will post a final pic when the case is properly finished.
PS a few more pics on my so called website
Cheers
Jye
Old 7th February 2005, 07:17 AM   #2
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
Looks good.. link broken.. here though.
http://www.users.on.net/%7emefinnis/passlabs/aleph5.htm
Baby Danika, Born January 20th 1:54am..
http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect..
Old 7th February 2005, 07:29 AM   #3
csmith is offline csmith  Australia
Wow, cool.
It looks nearly as good in the picture as it does when I saw it in person on the weekend.
Old 7th February 2005, 07:33 AM   #4
Taco is offline Taco  Netherlands
Wow, nice metalwork! About the hum, you say you've used a crappy pot. Maybe an external grounding problem?
Old 7th February 2005, 07:52 AM   #5
Hi Jye
well done and congrats.
Looks like you've used the same heatsinks I ended up going for...
Mine in FINALLY going, not without some assistance from Mark (I pinched his Variac)
My thermal cutouts are about 3-4cm from the mosfets and have not cut in yet with a heat rise over ambient of 37deg. (measured between fins near fets)
Voltages similar to yours excepting offset which is a bit higher.
I hope you are as happy with yours as I am with mine..
Cheers.
george a
Old 7th February 2005, 08:13 AM   #6
Jye's Avatar
Thanks for the comments guys.
Taco I think the hum is the same problem most people have with their power supplies, but I could be wrong. Will have a look around with a CRO soon and see.
George you say yours rises 37C above ambient temp....well on the week end that would put mine just over 70C since we had 35C all weekend up here in Brisbane As for the sound, when get some sort of decent preamp I will comment BUT I will say I can hear an improvement in the bottom end.
I didnt have a Variac so I just bit my lip and turned it on and all was good
Jye
Another Aleph X up and running xavier1000 Pass Labs 94 17th March 2011 07:20 PM
F2 running hot(how hot is hot?) Aron Pass Labs 10 13th February 2009 04:42 PM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 03:34 PM
Aleph-x running, but a little problem oliverniekamp Pass Labs 18 7th May 2006 07:18 PM
New aleph 5 up and running, have a few ??'s about my measurements. RKC Pass Labs 3 23rd December 2002 05:36 AM
Page generated in 0.09037 seconds (77.12% PHP - 22.88% MySQL) with 11 queries
