Hi!
I would like to ask the experts, what kind of laudspeaker is ideal for such a low damping factor amps like the SOZ or ZenLite? I mean: Qts or any TS parameters? Vented or Closed or TML, 4 or 8 or 16 Ohm? surround material:gumi or polyfoam? Magnet material? etc.. Tyimo |
#2 |
The one and only
I recommend going to Madisound and checking out the
Fostex products, particularly the FE166 and FE206 types for single driver, and some of their others if you want to consider using a tweeter. If you have a higher budget, then look at Lowthers. My favorites are the DX4 and DX55. Particularly with SOZ, check out the article at www.firstwatt.com There are lots of other alternative high efficiency speakers, including older Tannoy, JBL, Altec and Klipsch, and among state of the art these days, we would have to list TAD.
#3 |
Hi Mr. Pass,
I'm interested in the FE166E. Can this work in a bookshelf size enclosure instead of the large horn designs? Does Qts matter with horns? How good can it sound? Would B&W owners be envious? Tom |
#4 | |
Soon gonna test the driver (~2 weeks) and can let you know as I will build the 15l recommended to let it break in. greets
jens |
#5 | |
http://www.fostexinternational.com/d...6e_enclrev.pdf
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#6 |
Look forward to your review in the bass reflex enclosure.
What type of surround do these have? Doesn't look like rubber. Tom |
#7 | |
The one and only
bottom end by driving it with a current source. In a folded QWTP they work quite well with lower source impedances, say 10 to 15 ohms. I also have a set of Abbys with them, again driven by about 15 ohm sources. Lastly, I have loaded them in the Kleinhorns, where they gave somewhat similar performance to the Lowther C45 and DX55, and where I use a current source with an active high pass filter. In all these cases, I get more bottom end with a finite source impedance, and this also gives me the opportunity to load the upper mid and top with an RC network across the driver to perform some "baffle step correction". A typical starting value is 10 uf in series with 10 ohms. So in general I think you can get very good sound, depending on your taste and your willingness to experiment. I like the driver very much. I prefer its slightly higher BL product over the FE167, but the difference is not much to my ears. Currently I'm playing with the FE166ES-R which is the snazzy big magnet version. Let you know about that when I'm done.
#8 |
Voltage amps I can understand but I'm not sure what is meant by current source amp.
Are the SOZ or ZenLite current sources? Thanks Tom |
#9 |
#10 | |
The one and only
having approximately the right source impedance of 16 ohms. |
| Perfect hole for speaker... | Gold_xyz | Multi-Way | 3 | 2nd November 2006 05:32 PM |
| New kit speaker -perfect for other enclosures | Scottmoose | Multi-Way | 4 | 8th February 2006 07:40 PM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Chipclone and speaker: suggestions for a perfect combination? | Franz G | Chip Amps | 104 | 6th November 2004 12:34 AM |
| the perfect speaker | scottie2hottie | Multi-Way | 9 | 4th November 2002 02:10 AM |
| Page generated in 0.47823 seconds (28.49% PHP - 71.51% MySQL) with 11 queries |
