Old 3rd February 2005, 01:38 AM   #1
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Default Aleph output resistors
I'm gathering stuff for my A5 ...
I wonder about those output resistors - 4 0R47 in parallel - 3W each ... If I understand it right - there are four in parallel from two reasons:
- no need for bigger power factor/resisitor
- 0R47 / 4 is more precise than single 0R117R one ...
But I wonder - I intend to buy Mills resistor - but they are quite expensive - but also allready 5W ones - I gues it won't hurt to use just two 0R23 ones?
Old 3rd February 2005, 01:53 AM   #2
As long as the resistance is right and you have the ability to dissipate sufficient heat you can use any combination of resistors you like. The precision aspect isn't really much of a factor--sure it's nice if you can hit the resistance on the button, but it's nothing to get sweaty about. You might want to check the balance between the gain device and the CCS when you're done, just to make sure that you haven't changed that part of the equation. But then, that's something you'll want to do anyway, as the thermal environment plays a part in the interaction of the output devices.
Grey
Old 3rd February 2005, 02:25 AM   #3
jonk is offline jonk  Canada
jonk's Avatar
I love this place. I’m was just wiring up my boards when I thought I’d look up output resistors and the topic is right at the top of the list.
Gray: When you say precision isn’t much of an issue, to what reasonable limits you mean. I’m making mono blocks with 30-volt rails and 8 fets per amp (4 gain and 4 CCS). My source resistors are 0.5R. My understanding is that the output resistor array should be close to the combine parallel source resistors (8 x 0.5 = 0.0625R). I have a nice 0.1R Caddock 25W resistor in my parts drawer I’m wanting to use…do you think that’s too far off?
TIA
Old 3rd February 2005, 02:58 AM   #4
Stabist's Avatar
Aha - thanks ...
Btw - how can I estimate power dissipation for those fellows ---
And what is with this interconnection with source resisitors?? Didn't now that they are connected ...
I intend to use 0R82/3W resistors instead of 1R (R40-42 and 64-66 in original schematic) in the schematic - that's a value from experiences with friend's A5 assures 60W/8R ...
Oh and yep - pass section of this forum IS a a GREAT place
Old 3rd February 2005, 03:38 AM   #5
jonk,
Speaking for myself, I'm spoiled...I regard 5% as the outer limit for resistors and prefer to stay less than 2%. Caps and such are another matter, as it's difficult to find tight tolerances, though I'm using 1% caps in the phono stage that I'm working on.
Stabist,
Easy. Just figure out how much current is likely to pass through them and do the I-squared-R thing. For instance, 60W into 8 ohms is roughly 2.75A. Get out your trusty calculator and run that (squared) across whatever R you end up with. Then double that, just because.
Mind you, it's not likely that you're going to run the amp at full power for any length of time. Maybe a few minutes of testing or something, but not with music. So there's a bit of leeway right there. Another factor is that resistors are pretty hardy beasts and can take some punishment. That's more leeway. Still, it's best to be polite to your parts. Run them at half power or less.
The relation of the Source resistors and the output resistor array is described in the patent.
Granted, it's been a while since I scrutinized the 60 schematic, but the 5 should do 60W into 8 ohms without a problem. If I recall from back when I was studying the Aleph series, Nelson set most of them up with sufficient current to go down to about 5-5.5 ohms. The 30W was the exception, as it would double into a 4 ohm load. Not that I'm trying to discourage you from increasing the bias--just make sure you do it for the right reasons.
It sounds better.
Grey
Old 3rd February 2005, 04:33 AM   #6
Stabist's Avatar
Grey thanks - I'm a bit for asking for basic formulas and for showing I didn't thoughtfull read the patent
About increasing the bias - practical experinces with Kirc's A5 are that with source resistors 0R82 and that current ratio of the current source around 62% I can get around 90-100W/5R - and that's what interests me - since my speakers are 5R ones ... Without that - it has almost same power at 4R than at 8 ...
THANKS again!
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
Resistors in Aleph-X Hastur Pass Labs 8 7th February 2006 10:18 AM
Resistors in Aleph 2 diyman Pass Labs 1 4th May 2003 06:57 PM
Aleph 5 resistors vossie Pass Labs 11 26th February 2003 12:44 PM
Aleph 2 resistors ? jeclk Pass Labs 0 23rd October 2002 08:56 PM
Page generated in 0.10006 seconds (76.62% PHP - 23.38% MySQL) with 10 queries
