Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 2nd February 2005, 05:54 PM   #1
Default CLC Question - Heat Dissipation
I am going to use a CLC arrangement in my power supply for an Aleph 2 and have some 2.2mH copper foil inductors.
My question is: Will the plastic coating on the inductor handle the heat generated by the power supply? Should I be concerned with this?
Thanks for any advice given!!
Old 2nd February 2005, 07:36 PM   #2
Magura is offline Magura
Magura's Avatar
The easy way to find out is to throw the inductors in an oven at 110C and see what happens.
I would though advice against using inductors of unknown materials. If you stick to magnet wire of reasonable quality, you know what you get.
Magura
Everything is possible....to do the impossible just takes a little while longer.
Old 2nd February 2005, 09:01 PM   #3
Stuart Easson's Avatar
Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
Default Heat?
Since you are building this PSU, presumably you know the RMS current it is expected to supply, so it is pretty easy to figure the internal dissipation of the chokes. In the case of the Erse, iron core inductors I use, it is 6A x 6A x 0.16ohms, or about 6 watts, I can barely detect a change in temperature of the devices.
OTOH If you are worried about the temp of the environment they will be housed in exceeding, say 60c, you may have other issues you need to address. The rectifer and transformer supplying the chokes will be much worse off...in fact any electrolytics and semiconductors in the immediate vicinity will be suffering and may change characteristics enough to need adjustment...
Stuart
Thread Tools
A3 heat dissipation problem spTOH Pass Labs 4 3rd October 2006 06:45 AM
Need help: 5687 tubes and heat dissipation Mrpong Tubes / Valves 6 20th March 2006 04:07 PM
Heat dissipation from 3875 soundNERD Chip Amps 3 19th January 2005 02:03 AM
Heat dissipation Magura Pass Labs 26 15th November 2003 01:00 PM
Dramatic Heat Dissipation drop on SoZ Super_BQ Pass Labs 1 8th October 2001 03:01 PM
Page generated in 0.16913605 seconds (61.48% PHP - 38.52% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
