Old 2nd February 2005, 02:39 PM   #1
Default aleph 5 oscillating???
Hi all
After much stuffing around i have seperated A5 power supply for the pcb's and output mosfets after upgrading heasinks to much larger size.
However i now have other problems which I didn't have before!!
1. I now have approx 1V offset at speak terminals as opposed to approx 50mV previously.
2. I now have hum at ouput (even with now input wiring to pcb.)
3. Votages on pcb appear ok.
4 . voltage across 1 source resistor on one mosfet starts off ok then rises rapidly and the other mosfets current essontially drops to zero....ish.
Is this one mosfet oscillating.????
I replaced it with another (matched ) and again voltage started off ok and then started to rise, is the mosfet dud , (it has 33ohm across gate to source...
the ouptut mosfet are only a couple of inches from the pcbboard.
any suggestions.????
thanks in advance
cheers
george a
Old 2nd February 2005, 02:53 PM   #2
The negative rail of the front end has to be the same as the negative rail on the output stage.
Jeremy
Old 2nd February 2005, 03:01 PM   #3
Hi Jeremy
They are the same as they are fed from same point
I am using Mark Finnis PCb + mosfet pcb's
BTW I removed 1 ohm source resistor and turned on to check other mosfet and the resistor R22 221ohm which goes from Q2 (Ztx450) to junction between source of mosfet and 1ohm resistor ended up smoking itself
george a
Old 2nd February 2005, 07:29 PM   #4
Anybody ...please??
george a
Old 2nd February 2005, 11:53 PM   #5
please..??
BTW I don't have an oscilloscope to have a look at what's happening
george a
Old 3rd February 2005, 06:08 AM   #6
anybody....please??
george a
Old 3rd February 2005, 07:52 AM   #7
Electrons are yellow and more is better!
peranders's Avatar
The experts sleep sometimes
/Per-Anders (my first name) or P-A as my friends call me
Old 3rd February 2005, 08:46 AM   #8
Yes Peranders , the experts do sleep sometimes.
the problem is idiots like ME stay up all night worrying about what we've done wrong.
Sweet dreams , good night - sleep tight
regards from down under
george a
Old 3rd February 2005, 11:13 AM   #9
macka's Avatar
Sounds like a wiring fault,
Post a few pictures so we can understand
Macka
Old 3rd February 2005, 12:48 PM   #10
sort of a wiring fault macka
looks like a dodgy 1 ohm resistor in the location that's blown 2 mosfets so far.
I replaced the mosfet with a sacrificial non matching one and put in a 1.5 ohm resistor just to see what happens....
result :
the non matched mosfet is pulling about twice the current of the others...
no hum (well almost all gone -acceptable level)
offset 6.7mV
heatsink is warming up...
I will get to shops tommorow to purchase new 1 ohm resistor...
there is much to be learnt in putting these things together!!!
Ta
george a
PSU oscillating apolon34 Power Supplies 3 24th June 2005 02:20 PM
Aleph-X oscillating. What to do? AudioAngel Pass Labs 15 26th March 2005 07:17 AM
Oscillating DoZ rchua77 Solid State 1 30th January 2004 10:07 AM
Is your Aleph oscillating? kenny_(00)_ Pass Labs 5 2nd September 2003 04:46 PM
Page generated in 0.09318 seconds (88.05% PHP - 11.95% MySQL) with 10 queries
