BOSOZ Balanced Attenuator Set-up
Old 31st January 2005, 09:34 PM   #1
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Question BOSOZ Balanced Attenuator Set-up
I'm interested in hooking up a 24 position rotary switch based ladder attenuator to a BOSOZ for balanced out operation.
Attached is a diagram. Is it better to use 2 ladder attenuators one for each signal side, or can a person get away with using a single ladder network similar to the Pass D1?
Is there a difference in sound quality between the two alternatives? The D1 type setup is certainly less expensive.
Thank you for the help and suggestions!
-David
Old 1st February 2005, 11:41 AM   #2
jh6you is offline jh6you
Account Disabled
As far as I understand, the volume of D1 installed between the drains of the current-to-voltage inverter is simply a variable resistor. Its value is closely related with the two 1.5k Drain resistors so that we can change the voltage occurring across the volume resistor, by adjusting the volume knob. Both ends of the volume resistor always have the same voltages but opposite polarities, and they face Gates of the buffers provided to minimize output impedance. The concept of this volume is considered quite different from the normal volumes we are using for normal preamps.
If you are going to use balanced inputs for your power amp, I would like to recommend the volume A.
Any different opinion?
Old 1st February 2005, 12:41 PM   #3
Account Disabled
Or, if you like to try the volume B, I think that some modification is necessary.
Old 1st February 2005, 06:13 PM   #4
hifimaker's Avatar
Thanks jh6you for the hints.
Has anyone tried option B in the attached schematic like the D1 for either the BOSOZ or Aleph P?
Curious to see if it is posible, and what else has to be done.
Thanks!
-David
Old 1st February 2005, 08:18 PM   #5
eLarson is offline eLarson  United States
eLarson's Avatar
Perhaps you will be first?
Would a woodchuck bother to chuck MDF?
Old 2nd February 2005, 03:25 AM   #6
Account Disabled
I would try the option B as shown below. Resistor values could be selected for the suitable amp gain and volume level. Hoping your success...
BOSOZ Balanced Attenuator Set-upHide this!Advertise here!
attenuator balanced 600/600 alexidoia Parts 2 13th February 2006 08:38 PM
BOSOZ--variable impedance volume attenuator jh6you Pass Labs 22 15th March 2005 08:34 AM
BOSOZ balanced connectio BBB Pass Labs 5 3rd April 2003 11:53 PM
Resistor values of stepped attenuator for BoSoZ stappvargen Pass Labs 1 21st February 2003 12:29 PM
BoSoZ stepped attenuator cjunk Pass Labs 47 12th December 2002 07:59 PM
