Old 29th January 2005, 10:55 AM   #1
Tyimo is offline Tyimo  Hungary
Default BOSOZ PSU question
Hi!
I would like to build the BOSOZ's PSU with lower regulated voltage, ca. 40 V.
I know that: ".... It is possible to set up the power supply to regulate at lower voltages. Alternately, you might choose a single transformer that does not develop as much voltage as two D4007's. Simply replace some ofthe Zener diodes with shorting wires to produce lesser referencevoltages in increments of 9.1 Volts, or replace the 9.1 volt parts withother values....."
My question is:
-what kind of transformer is ideal for the the desired regulated 40V, if I would use 7x5.6 zenners?
Tyimo
Old 30th January 2005, 04:15 PM   #2
Account Disabled
Nelson Pass prefers the toroidal transformer.
I use a toroidal transformer for my BOSOZ, but will not hesitate to use EI type if available.
Old 30th January 2005, 09:39 PM   #3
eLarson is offline eLarson  United States
eLarson's Avatar
When using lower voltage rails, you could probably scale back some of the resistor sizes from the original article, giving you higher bias current and a little higher drain voltage than with the original resistors.
Would a woodchuck bother to chuck MDF?
Old 31st January 2005, 04:49 PM   #4
Hi!
Thanks the answers, but I mean/ask, how many secondary voltage of the toroid need for the desired regulated 40 V?
Tyimo
Old 31st January 2005, 04:53 PM   #5
sorry, one more thing:
I already built the BOSOZ and it is excellent! I would like to use the PSU board for an another preamp project!
Thanks!
Tyimo
Old 31st January 2005, 06:28 PM   #6
eLarson's Avatar
Sorry, Tyimo... I looked back at my post and it appears to be a bit of a non sequitur.
For ~40VDC rails you could probably get by with a transformer secondary in the 30 to 32V neighborhood, presuming that you're going to use a cap-input supply and not a choke-input raw supply.
Erik
Old 1st February 2005, 04:42 PM   #7
Erik: Thanks.
I know the x1.41 rule, but I ask for the regulated PSU voltage?
I mean: in the original article: You use 60V secondary, get 80V unregulated DC and in the end you get 60V regulated DC.
So, should I use ca. 40V secondary to get the desired 40 regulated DC?
Greets:
Tyimo
Old 1st February 2005, 04:58 PM   #8
BobEllis's Avatar
Somewhere over 32 VAC would give you enough to drop ~5 volts in the regulator - about the minimum using FETs.
40 VAC will be work but watch the heat sinking of the regulator pass transistor. You'll need more than a clip on heat sink since you'll be dissipating more than 2 W if you run both channels from one regulator.
Old 1st February 2005, 05:11 PM   #9
Thanks Bob!
Now I see.
Greets:
Tyimo
Old 1st February 2005, 05:14 PM   #10
Oh, and do you mean it with 7x5.6 zenners?
BoSoZ PSU Question Raoul Pass Labs 4 8th March 2005 02:44 PM
bosoz question... cowanrg Pass Labs 9 27th November 2004 01:39 AM
BOSOZ with CCS, and a question jh6you Pass Labs 11 26th March 2004 05:25 AM
BOSOZ PS Question vdi_nenna Pass Labs 5 4th August 2003 10:25 PM
Bosoz psu question protos Pass Labs 8 25th November 2002 03:39 PM
Page generated in 0.09470 seconds (77.24% PHP - 22.76% MySQL) with 10 queries
