Kinda belongs in the Pass Labs area I think...
Anyway, I was doing a sim of a pair of choke loaded source followers in an X-amp configuration (dreaming up my next project) and it occurred to me should the drive signal be centre-tapped and therefore each end be totally independent, or should it be floating so that the drive signal to either side is referenced to the opposite side and it's nonlinearities. On the schematic, if I break the link from R13 & R14 to ground the circuit gives basically the same results (unmeasurable distortion ) but the when driving things a bit hard the source waveforms look different depending on the drive. Seems to me the two drive setups are fundamentally diferent, so which is best?
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#2 |
Red is Q2 source with centre-tapped-to-earth drive,
Blue is Q2 source with floating drive. Green is voltage across load R2 either situation.
#3 |
I don't see that R13 and R14 do anything useful here. Seems to me that, if they are low enough in value, they will defeat the cross-coupling by acting as shunts around R11-R4-L2-R3 on one side and R10-R9-L1-R1 on the other. OTOH, if they are very high in value, they won't do anything good or bad that I can see.
There would appear to be a small DC voltage to ground on each side of V3, so presumably it too is a floating element - possibly a transformer secondary or the output of a preceding balanced gain stage? I've been a bit absent-minded lately, so if I've missed anything obvious, please don't take it personally! |
#4 |
The one and only
Unless I mis-interpret the question, a "virtual" ground will
work just fine with an X amp as long as you don't connect the output to this ground.
| Modify 4-wire NewClassD PSU module for use with centre-tapped transformer | cdl | Class D | 7 | 13th March 2009 09:08 PM |
| FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. | Dougie085 | Swap Meet | 0 | 3rd May 2008 07:31 PM |
| Phantom centre channel with centre channel lol | Toast_Master | Multi-Way | 5 | 5th December 2006 03:54 AM |
| centre tap or floating heaters? | lt cdr data | Tubes / Valves | 3 | 23rd August 2006 06:35 AM |
| Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive | kelticwizard | Everything Else | 12 | 22nd January 2003 03:34 AM |
| Page generated in 0.08193 seconds (72.36% PHP - 27.64% MySQL) with 11 queries |
