I am planning to do my first amplifier-project, the bzls.
As I'm a newbie in circiut design I spent long nights reading up and down through the net to gather information The result is a never ending list of links and many useful hints on the topic - thanks to this forum. What I didn't find until now was a layout to make an appropriate input switch for the amp. It would be nice if someone could help me! Joseph |
#2 |
The one and only
If you want to switch more than 2 inputs, you're stuck with
4 poles of switch per input. Practically speaking this is two 2 pole relays per input stereo pair. |
#3 |
Joseph, I have used digital switches for such things in the past. The new generation of digital controlled analog switches have an on resistance below 10 ohms. They can be break before make and use bcd control or direct control. If you are interested, let me know and I can forward the info to you.
If you have sources with unbalanced output, check out Analog Devices SSM-2142 balanced line driver. This chip is used in 90% of the mixing consoles I have worked on. It also makes an easy way to bridge a stereo or two mono amplifiers. Regards, Steve
Finding new ways for the extreme mis-application of high tech! |
#4 |
Thank you for your replys
I'm planning to switch 4 inputs As I have some MEISEI relays (alternative for TAKAMISAWA relays?) and a couple of DPDT switches (crossbar), I would like to use them if they are suitable. Are they regards, Joseph |
| Balanced line stage- input or output attenuator | nobody special | Pass Labs | 4 | 7th April 2006 01:18 PM |
| balanced input stage | sonix | Tubes / Valves | 54 | 5th June 2004 02:47 PM |
| Balanced Zen v5 + balanced Zen line stage | Adrie | Pass Labs | 0 | 30th May 2004 05:27 PM |
| Balanced Input Stage | Bukitoo | Solid State | 5 | 11th March 2004 03:03 AM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Page generated in 0.07476 seconds (76.85% PHP - 23.15% MySQL) with 10 queries |
