I am in the middle of putting together an Aleph 5 (using Mark Finnis PCB) and would like to up the bias as high as the heat sinks allow once completed (possible removing R19) Cheers Jye |
#2 |
625 VA should be fine
#3 |
I used a 625 VA transformer on mine and it works fine for me.
Steve |
#4 |
Thanks for the replies.
Did u increase the bias SteveA and if so to what? |
#5 |
Jye-
No, I built it as per Pass schematic (at least main boards and output boards). For PSU I used a CLC (68000-2.2mH-68000 on each rail). I used a single rectifier as per Wayne Sankey's Aleph 2 (see Passdiy). SteveA |
#6 |
hi there Jay
I built an Aleph 5 with standard bias using a 625VA transformer and feel that it is under a bit of stress. It tends to get hotter than I am accustomed to. If I were to build another Aleph 5 I would select at least an 800VA transformer, especially if I wanted to increase bias. Regards Dirk |
#7 |
If you can afford it go for the 800 (or twin 500). You may regret it later (and then changing is a lot more expensive)
Is that all there is? |
#8 | |
The one and only
transformer/ caps/ heat sinking accordingly. If you can't scale the heat sinks, you'd be amazed at what a little bit of air flow will do for you.
#9 |
Thanks for the reply guys, I will go with the 800 since I plan to up the bias as high as I dare
I hope to post some finished results in 2 - 3 weeks...only a few things missing. Jye |
#10 |
jye,
I use 625w transformers for an aleph 5. The amp sounds ok, but in the first 20 minutes there is a mechanical hum from the transformers, no hum to the speaker !. The bias is about 20 % higher then the original aleph. So, take a 800W transformer. |
| FS: (Australia) Evox Rifa caps and a 625VA transformer on eBay | Cloth Ears | Swap Meet | 0 | 4th January 2008 06:43 AM |
| FS: Avel 625VA 30V+30V Transformer | mfb | Swap Meet | 1 | 12th July 2007 06:59 PM |
| Avel Lindberg 25-0-25 625VA transformer | cotdt | Swap Meet | 1 | 1st May 2007 04:54 AM |
| Plitron 2x25V 625VA transformer | bjefferys | Swap Meet | 5 | 14th April 2006 12:24 PM |
| Toroids 2 x 35-0-35 625va suit Aleph 2 | dhole | Swap Meet | 0 | 2nd August 2005 08:33 AM |
| Page generated in 0.09758 seconds (76.82% PHP - 23.18% MySQL) with 11 queries |
