Hello all,
I almost finished my soldering activities for one channel of Aleph 5. I would like to test this channel, but I'm wondering if someone could enlighten me on the startup sequence. Do I damage the mainboard if I start it up without output mosfets? What I would like to do is: First, connect the mainboard and check voltages. Then, connect output boards and check for DC offset on the output. Any more ideas on starting up Alephs? Regards, Jarno.
Oemptempa petoempetapap |
#2 |
Hi Jarno
I started up my A5 without the output mosfets, you can't measure all required voltages. Mine was not damaged by leaving them out. Try a variac to slowly apply voltage to Power supply if possble, I used a light bulb in series... quadruple check correct orientation of the ztx450/mpsa etc transistors. refer my postings at aleph 5 help...please cheers
george a |
#3 |
Thanks George, I will go through your posts in the thread you mentioned. Good to know I can power the thing up without the output mosfets, saves me some soldering if something is proved to be wrong. The correct orientation of the small transistors is something I am curious about, as I've reversed them because of the different pinout of the BC550's I used.
I do have a variac somewhere, I'll have to dig it up and find a way to mount a knob on it (apparently, the previous owner didn't bother to properly disassemble it and used a hacksaw). Regards, Jarno.
#4 |
Jarno-
I have just built an Aleph 5 and, with help from another member, found out that by shorting to ground the common point of R7, C6 and C8 one can check the voltages as per the Aleph 5 schematic . SteveA |
| Tube Amp Startup | DreadPirate | Tubes / Valves | 30 | 14th August 2008 01:56 PM |
| Startup Cost? | thereverend | Tubes / Valves | 23 | 22nd August 2007 06:37 PM |
| ZV5 Startup Troubles | keenlyside | Pass Labs | 0 | 13th June 2005 06:35 AM |
| Page generated in 0.07424 seconds (73.69% PHP - 26.31% MySQL) with 10 queries |
