About passive crossover - diyAudio
Old 2nd August 2002, 06:18 PM   #1
Default About passive crossover
About passive parallel crossover.
Generally all the passive crossover are referred to ground .When an amplifier has its outputs + and – live (balanced) and a symmetric topology like Son Of Zen, does the crossover (with a ground referenced topology) affect performance of the system?
Well if I am not wrong a parallel crossover can be arranged :
Old 2nd August 2002, 06:42 PM   #2
Sorry , how to attach an image?
Old 2nd August 2002, 07:05 PM   #3
AGGEMAM is offline AGGEMAM  Denmark
AGGEMAM's Avatar
Save it as .gif first, then..
oh .. just check the faq.
Hmm .. no .. I really haven't got anythig cool to say ..
Old 2nd August 2002, 07:31 PM   #4
Thanks AGGEMAM for reply . I try...
Old 2nd August 2002, 07:35 PM   #5
YOOOOHOOOOuuuuuu.....
For simplicity I have showed only a simply low –pass filter . But I do the same thing in the hi-pass half of the crossover dividing resistors and doubling capacitors .
That is what I do with my system . The filtering is somewhat modified? Also can this reduce the distortion of the system amp-speaker? Comments are welcome.
Old 2nd August 2002, 07:39 PM   #6
AGGEMAM's Avatar
When a filter refers to ground, but the amplifier is push-pull coupled, then the filter really refers to the negative pulling part of the amp.
You filter suggestion only adds another component to the filter, and it is generally not considered a good idea to seriel connect two inductors.
Passive Crossover Upstream of Amp? NV&H Multi-Way 3 20th June 2009 04:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Passive crossover Twisted Parts 0 19th January 2004 08:32 PM
Copyright ©1999-2017 diyAudio
