Hi everyone,
I have a good friend with a pair of factory Aleph 30's driving a pair of Martin Logan Aerius i's. How far can the bias be safely turned up to drive these lower impedance speakers a bit better? Hoping to get more power into 2-4 ohms. Thank you, -David |
#2 |
All you dare. But then again watch the heat.
You should be able to touch the heatsink for five seconds...without gloves. /Hugo |
#3 | |
The one and only
#4 |
That's what I was afraid of. The amp would sound good for a few minutes and then...
Appreciate the the kind help. -David |
#5 |
The one and only
You can do it, but you really can't increase the bias enough
to make that much difference. Easier to just start with a larger design or get some Lowther or Fostex drivers.
#6 |
You could parrallel the inputs and the outputs of the two channels to get more drive...I've have some home brew aleph threes running this way for the last 2 years
| Max safe operating temperature for transistors inside modified factory amplifier | azzajonesy | Solid State | 8 | 8th October 2008 12:00 PM |
| low cost, small, safe bias supply | I_Forgot | Planars & Exotics | 36 | 1st June 2006 02:57 PM |
| increase the bias current of an opamp final stage | herve | Solid State | 19 | 15th September 2003 12:29 PM |
| Page generated in 0.09355 seconds (77.12% PHP - 22.88% MySQL) with 10 queries |
