Old 14th January 2005, 06:35 AM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Tech help needed Threshold S/300 MkII optical bias
Hi guys, i need help with this amp it has 77k input impeadance and i need to up that to 200k, is it possible by just changing the resistor that goes across C3 i think it`s r18 or 10, without upseting the dc offset or bias or anything?
Also can anyone tell me what the switch is to the right of that resistor is for?
The reason for uping the input impeadance is for the high source impeadance that i`m driving it with, and it`s also in a bi-amped setup.
Nelson if you read this can you help please, after all you designed it.
And thanks to Dave (planet 10) for shrinking the circuit to the right size.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 16th January 2005, 10:48 PM   #2
georgehifi's Avatar
This post has been put in Solid State forum and has a lot more disscusion on it.
And if anyone is interested a different kind of volume control that blows away any brand of poteniometer.
Cheers George
Old 17th January 2005, 09:22 PM   #3
The one and only
Nelson Pass's Avatar
You can set R18 at just about any value that you like.
Try a 200K - the JFET's input impedance is so high that
it should have little or no effect.
Old 17th January 2005, 10:09 PM   #4
georgehifi's Avatar
Nelson thanks, did it to 330k, no chage in dc offset or bias, i`m a happy man now. ( change to solid state forum, lot more intrest there) Tech help needed Threshold S/300 MkII optical bias
Is it possible to increase the gain a few db simply with a resistor change to r17 or what looks to be r6or8?
Also can you enter the circuit that i painfully obtained into your circuit data bank http://www.passlabs.com/np/ as it`s about the only one that you did`nt have listed.
Cheers George
Old 18th January 2005, 06:49 PM   #5
The one and only
Yes.
Threshold S/500 bias set up anyone? stevieg123 Pass Labs 28 30th January 2010 03:17 PM
Threshold SA4/e bias nchelazzi Pass Labs 2 16th June 2008 08:10 PM
Tech help needed Threshold S/300 MkII optical bias georgehifi Solid State 15 17th January 2005 01:30 AM
optical bias, how does it work? Hardi Solid State 6 11th September 2004 02:08 PM
Threshold Stasis S/300-2 optical a-ab georgehifi Solid State 3 30th September 2003 02:18 PM
Page generated in 0.08418 seconds (81.70% PHP - 18.30% MySQL) with 11 queries
