What have I built?
What have I built?
Old 13th January 2005, 08:53 PM   #1
george a is offline george a  Australia
Default What have I built?
HI all
After much stuffing around , misunderstanding, and generally not knowing what I'm doing,, I've managed to build a version of an Aleph AMP,
It was Intended to be an A5, using some left over parts but most notably as some may have noticed in other threads, some undersized and Fan cooled heatsinks.
In short at the end of the day its spec's are essentially as follows:
Supply Voltage +-36V from 50VCT 50A trafo
PS caps 4 X 80KuF
Reduced bias to keep thermal trips on hetsink adjacent output itf240's -I have 0.36V across 1 ohm resistors attached to irf240's (A5 should be 0.6V accord to schematic)
Total 6 mosfets per channel.
IRF240 case temperature 59deg C stabilized (at last)
offset about 50mV
I think others out there know the math to work out what power output I can expect and I would be greatful for any comment.
Have I built a mini Aleph??
BTW it sounds great! (is being used in a triamp system as a mid -range amp and I have also tried it full range- very nice indeed)
Cheers and thanks in advance
george a
Old 13th January 2005, 09:18 PM   #2
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
sounds kinda like an aleph3 maybe? maybe a 30?
Old 13th January 2005, 09:47 PM   #3
metalman is offline metalman  Canada
metalman's Avatar
Did the off-the-cuff calc's, and it looks like you have approx. 20W into 8ohms and 10W into 4 ohms. Your amp's power output is current limited across the impedance range at this point, giving you more or less a MiniA.
If you can find a way to improve your cooling (bigger heatsinks or add a fan, etc.) you could increase the bias. Based on your trafo rating, with increased bias you could upgrade to somewhere between an Aleph3 and 5.
Cheers, Terry.
What have I built?Hide this!Advertise here!
Who has built their own? markp Solid State 43 3rd August 2014 10:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 10:12 AM
i built these a while ago and roystr Full Range 11 10th November 2005 01:49 PM
Anyone built this amp? JojoD818 Solid State 26 19th August 2003 12:32 PM
Copyright ©1999-2017 diyAudio
