hello
excuse my English! I have much admiration for the work of Mr. Pass and I make a point of thanking it for his generosity I present a BOSOZ made in France it is not finished I put myself question for the mass ( ground ?) is what that is appropriate ? ![]() http://domainedupossible.free.fr/pag...SOZ/bosoz1.htm in french, sorry ! many photographs... thank you very much Phill |
#2 |
#3 |
Excellent work. And the pictures are very clear too. Thanks for sharing.
Excellent travail. Et les photos sont très claires. Merci de partager avec nous. |
#4 |
Great work After finish, tell us how it sounds
If you want power you must add control |
#6 |
thanks
the gears are fixed => no balance I have a small problem on a channel : the report is for later... Phill |
#7 |
hello
I finished the assembly I have two problems with certain discs, the sound saturates, not with all,some is volume . it is similar with the other sources K7,tuner... R3-4 is replaced by a resistance 1.5 k/2w...? R18-19 : too weak valeure ? I use an attenuator with 24 positions, 10K.(P3-4). in position 20, volume is not very high I don't benefit from the power of the amplifier (QUAD 405/2) (R15=430 ohm !) if not the sound is very good. my system is better I am with the listening of all proposals Phill peut etre que PierreG pourrait m'aider pour la traduction?
#8 |
[QUOTE]Originally posted by Phill
[B]hello excuse my English! I have much admiration for the work of Mr. Pass and I make a point of thanking it for his generosity I present a BOSOZ made in France it is not finished I put myself question for the mass ( ground ?) is what that is appropriate ? ![]() http://domainedupossible.free.fr/pag...SOZ/bosoz1.htm Nice work. All grounds from each inputs, each outputs and gain stage should meet at one point. This is termed "Star" ground, a short length of wire from the power supply regulator ground with all grounds meeting this point is best. macka |
#9 |
now, the masses are good.
there remains the problem of saturation. it east can be possible to decrease the level of entry? to see the preceding message thank you with all Phill |
#10 |
R18/19 should be 220R.
Do you use P1/P2?, Important to have input attenuator. P3/P4 should be 5 K, 1.5 is a little and and will reduce output. See excellent article by Nelson Pass. Ian |
| Hello from France | ludovic.boyer | Introductions | 2 | 20th May 2007 01:02 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| Aleph 5 made in France | Phill | Pass Labs | 3 | 22nd December 2005 12:01 PM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 01:29 AM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Page generated in 0.10899 seconds (81.45% PHP - 18.55% MySQL) with 10 queries |
