Old 10th January 2005, 12:10 PM   #1
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Default AAL - another Aleph L
Hi!
Finnaly - one of the projects comes quite near to the finish line
It's an AlephL - the circuitry build by another forum member - Kirc - and the chassis iy my work ... It will be a preamp for Kirc's A5 ....
Old 10th January 2005, 12:12 PM   #2
Stabist's Avatar
It will have 4 inputs and two outs. Selector will be driven with relays. Attenuator is Alps Blue - 10k. Trannie is a very very good custom made EI with an EM shield.
Old 10th January 2005, 12:16 PM   #3
Stabist's Avatar
The circuitry itself is in use for more than half a year now - and it's great preamp! I find it superior to my BoZ - altough BoZ is build with Cerafine's, BG, etc - and AL with more or less standard parts (only 10uF are Wima's MKP).
The chassis outer dimensions are 300x260x100, front and sides are 10mm thick, other plates are 5mm ...
Old 10th January 2005, 12:22 PM   #4
Stabist's Avatar
The finish is supposed to be black eloxation - so I gues it will apear (just add two knobs) something similar to this chassis - which is on a good way to become my MC preamp:
Old 10th January 2005, 01:02 PM   #5
Great work!
Which version of the Aleph-L is it?
/Niclas
Old 10th January 2005, 01:14 PM   #6
Stabist's Avatar
It's the older version
Old 10th January 2005, 04:56 PM   #7
Nice job Stabist. Finally done! How does it sound?
I like that thick aluminum chasis.
Old 10th January 2005, 07:34 PM   #8
uli is offline uli  Austria
Hi Primoz,
These chassis look absolutely gorgeous!
How did you do them?
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 10th January 2005, 10:38 PM   #9
Stabist's Avatar
@bbakota
- AL as a preamp withhout chassis is in use for around 6months - I like it's performance a lot - just to ilustrate - altough it has only one input (no selector installed) - since the first test my BoZ didn't get the chance to be used again ... I don't now how to describe the difference - but there is ... It matches perfectly with A5 and also with Zen v4.
@uli
I order Al plates cutted to my dimensions - and the rest of it is my inspiration and work ... I must say that working with 1cm thick plates makes thinks much easier!!!! And it's not such a big difference in $$ between 4mm or 1cm ...
AL chassis - the material itself cost around 50Eur! I don't find that expensive ... But ofcourse - there are quite some hours of work in home workshop ...
Old 11th January 2005, 01:17 AM   #10
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
lookin GOOOODDDDD!!!
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.10075 seconds (78.82% PHP - 21.18% MySQL) with 11 queries
