After my first hours of listning itīs time to tweak this amp to perfection. I noticed a temperature difference between both heatsinks, and measurements showed that the bias of my left channel is 2.6 Amps instead of 2.0. I used the same parts for both channels, used the same wirelenghts and same heatsink. So one would expect same behaviour.
I used a fixed 221kOhm resistor for bias and 432Ohm for gain. Is it ok to assume everything else is ok (checked all the voltages: were ok) and just tweak the bias of my left channel to 2.0A by using a lower value bias resistor? ErikH. |
#2 |
yes,
or you could try another BC550 or whatever you are using. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#3 | |
| JBl GTS600, amplifier wanted! Dead or Alive, Alive if it can be helped:) | Paradise_Ice | Swap Meet | 10 | 5th August 2010 09:47 PM |
| My DIY Aleph 5 is Alive!! | john65b | Pass Labs | 21 | 3rd August 2009 12:13 PM |
| New Aleph-X alive! | AudioAngel | Pass Labs | 10 | 16th August 2005 08:30 PM |
| bias set for aleph | marijan | Pass Labs | 3 | 24th July 2002 05:46 AM |
| aleph bias, ... | janey | Pass Labs | 3 | 10th June 2002 12:40 PM |
| Page generated in 0.06699 seconds (67.53% PHP - 32.47% MySQL) with 10 queries |
