Old 7th January 2005, 03:25 PM   #1
Default aleph 5 wierd voltage p2pversion
Hi All
The saga continues
I've now built an A5 effectively point to point -(basically laid out the circuit straight onto perf board and voltages are still much like those of the pcb version.
Q4 & 5 are MPSA42
Q4 has 9.9V across it rather than 4-5 v
Q5 HAS 12.9 v Across it rather than 4-5v - it takes about a minute to reach this level.
The circuit is complete except NO output mosfets are installed.
and C5 is shorted to ground.
Are my wierd voltage readings due to output mosfets not being installed?????
I'm not game to install them to find out in case I lose more of them (5 dead so far)
Also how hot are the 9610's supposed to get ??
Supply Voltage is 36v
and R11 measures at 5.5 V instead of 4-5V - Drain of Q3 measures 3.5V instead of 4V.
Can anybody help please??
george a
Old 7th January 2005, 05:54 PM   #2
wuffwaff's Avatar
Q4 and 5 canīt have the right voltages across them cause the fets arenīt installed. The base voltage is normally set by the current through the source resistors.
Drain of Q3 is OK at 3.5V (Vgs and Vg =0V)
Current is a bit high (220ohms, 5.5V gives 25mA instead of 20). You could look at the zener or use a somewhat bigger resistor like 270 ohms wich will give 20mA bias)
Q3 dissipates 0,025A x 27V = 0,675 watt
Q1 and Q2 0,0125A x 36V = 0,45watt
Look at the datasheet for the expected temperature (Rth case to air)
The somewhat high bias canīt be the cause for the blowing of the fets and should normally even sound a bit better.....
Youīll have to check and recheck the wiring of the output stage. Try to start the amp with a variac and/or a lightbulb in series with the mains wiring (this will keep the fets from blowing by limiting the current)
Hope this helps,
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 7th January 2005, 10:39 PM   #3
well -- a couple of wires transposed in the output stage....DOH!
all voltages appear OK except for the 9.9V across Q4- is this what should be expected with no power mosfets installed?
Thanks to anyboy who can answer...
Cheers
george a
Old 8th January 2005, 07:47 PM   #4
wuffwaff's Avatar
9,9V across Q4 means that all the bias current from Q3 is going through Q1 (25mA x 390 Ohm = 9,75V) wich is possible if the gate of Q2 isnīt connected to anything.
William
Old 8th January 2005, 09:19 PM   #5
Thanks Wuffwaff
Looks like time to put in a couple of output mosfets.........
drum roll anybody....?
cheers
george a
Old 9th January 2005, 09:54 AM   #6
wuffwaff's Avatar
donīt forget the variac/lightbulb!
Old 9th January 2005, 10:51 AM   #7
Actually I prefer a series of Jacobs ladders to either a light bulb or variac.
Accordingly the power switch should also look like it came out of a power station.
george a
Old 9th January 2005, 05:36 PM   #8
wuffwaff's Avatar
What are Jacobs ladders?
William
Old 9th January 2005, 06:18 PM   #9
BDP is offline BDP  United States
Default Testing front end
Short across C5. This will trick the output into thinking it is a zero output offset and you should see the correct current through Q1.
This won't help testing Q4 or Q5.
PS - This will test the front end with the outputs disconnected.
BDP
Aleph 30 Supply Voltage TV Man Pass Labs 8 21st February 2008 06:35 AM
Best PSU voltage for Aleph 5 ? zeonrider Pass Labs 4 10th September 2007 10:16 AM
max. differential voltage in an Aleph P rsbay Pass Labs 1 28th February 2005 08:31 AM
C5 voltage in Aleph 5? bbakota2000 Pass Labs 2 15th March 2004 06:25 PM
transformer voltage needed for Aleph 4 or Aleph 2 diy student Pass Labs 23 28th November 2001 07:54 PM
Page generated in 0.10427 seconds (82.28% PHP - 17.72% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
