Ok, yesterday i bought a couple of the Calrad meters that monitor amperage, 0-10A.
http://www.calrad.com/calrad/index2.htm there is a pdf of a catalogue... p91 of the catalogue and 100 of the pdf. part # 60-171 there are only 2 connections on the back.. + and - where to I connect these on the my aleph 2's to monitor the bias? the meters will be on the back panels...not on the front thanks guys! -Matthew K. Olson |
#2 |
Basically, I'd just put them into the positive (ore negative, doesn't matter) supply rail, betwwen PSU and amplifier board.
What you measure there is the current through the output stage plus a negegible amount of supply current for the input stages. But: I am not sure if it was a good idea to buy ampere instruments. The problem is: They add a certain amount of restiance, which may not be a good idea there. The catalogue says, the meters come with a high power parallel shunt. What resistance does this shunt have? |
#3 |
The one and only
I use a cheap Radio Shack voltmeter across .1 or .01
ohm, depending. |
#4 |
It says in the catalogue that its 10mA/3ohm +par shunt. I dunno what that means. Voltmeter huh? Measures the voltage drop across a .1 or .01 resistor? Will that be accurate especially if the resistors are a little off. ?? Anyway, if i can't use the meter, let me know, and i'll return it and get a voltmeter. what value meter? doh!
-Matthew K. Olson |
#5 |
Let's see:
The meter itself shows 10 mA full scale and has a resitance of 3 ohms. So, there will be 30 millivolts drop. To retain those 30 millivolts at 10 amps, you will need a resistance of 3 milliohms, about 1000 times less than the meter's resistance. This is about the value the shunt sould have. 3 milliohms isn't much resistance and won't hurt anywhere, I would go for it |
#6 |
Ok, so i just put the + on the meter in series with the + capacitor and the - to the pcb? sounds intuative to me, but i'm making sure
do i want a 3 ohm resistor on the opposite rail just to even things out? how about putting it right after the inductor in my CLC filter...might make the wiring easier and would also allow me to use a 3 ohm resistor on the oppposite rail. Just a thought -Matthew K. Olson |
#7 |
I thought Nelson monitored the voltage across the source resistors for this sort of thing.........
Mark |
#8 |
ok, i got one guy telling my to go for it, and another telling me to
????-Matthew K. Olson |
#9 |
Okay, back up...what is it you're trying to do? If you just want something to watch, then either the rail or the Source resistor will do. If you want this to be a serious I'm-really-monitoring-something-here meter, then I'd go for the rail. Why? Because that will show the total bias current, which is the sum of all the individual output pairs. If you measure the voltage drop across the Source resistors, you'll find that they vary, one from the other, even though you matched them. If you're watching one, it'll always be in the back of your mind that the others are doing something different. By monitoring the total current, you'll have a more accurate idea of what is happening inside the amp.
Grey |
#10 | ||
This will give you a full scale reading at 10 amps of current draw. BDP |
| Bias Monitoring of Separate Heatsinks | DCPreamp | Solid State | 16 | 26th March 2007 03:11 AM |
| Aleph2 pcb's, matched fets for aleph2 and aleph ono pcb's | MemphisJim | Swap Meet | 1 | 23rd September 2005 07:15 PM |
| bias meter and pot lead length | frank2395 | Tubes / Valves | 2 | 15th April 2005 11:47 PM |
| bias meter | el capitan83 | Tubes / Valves | 4 | 20th December 2004 06:03 AM |
| Adding a bias meter to Zenlite | Michael Rothacher | Pass Labs | 11 | 4th February 2003 09:13 PM |
| Page generated in 0.10297 seconds (80.75% PHP - 19.25% MySQL) with 10 queries |
