Old 5th January 2005, 12:51 PM   #1
dhole is offline dhole  United Kingdom
dhole's Avatar
Default irf9610 matching and manufactures
Hi there People
Ive spent this afternoon matching up some irf9610 chips I picked. Up I was unfortunate enough to pick up a mixed bag although it was cheap . I am in the uk so £.80 each was good. The chips are mainly manufactured by SEC (14) and IR (6) . I havent had a problem matching and have a few sets of 3 . I am curious though about the manufacturer who I havent heard of . I am also curious about the vgs results which seem higher than I expected. They average 3.79v using a 1k resistor and a 15v psu as per Mark Finnis's pdfs on his aleph 4 . I dont have a problem it seems but I would be interested to know if the chips are any good in comparison to IR's ?
regards
dave
Old 5th January 2005, 12:54 PM   #2
dhole's Avatar
should i say that the SEC chips average 3.79 vgs and the IR 3.31.
Old 5th January 2005, 06:05 PM   #3
The one and only
Nelson Pass's Avatar
It varies from batch to batch even within a manufacturer.
Old 5th January 2005, 07:23 PM   #4
dhole's Avatar
I had guessed . But SEC as a company they are known I presume and make quality components ?
dave
Old 5th January 2005, 07:46 PM   #5
Send a message via AIM to yldouright Send a message via Yahoo to yldouright
Mr. Pass has indicated in earlier posts that matching the 9610 pair is better done in the circuit than out. Has anything changed since that post reference Mr. Pass? I also would like to know where to place in my standy switch circuit in order to have it draw only 3W like on your XA100 :?)
Old 6th January 2005, 06:10 AM   #6
lgreen is offline lgreen  United States
lgreen's Avatar
Default SEC
I believe SEC is Samsung Electronic Components or something like that. Subsequently got sold to Fairchild I think. Should be good quality.
Old 6th January 2005, 06:35 AM   #7
wrenchone's Avatar
SEC is definitely Samsung - OK quality, but IR, Siliconix, GE/Harris, Motorola/On are most likely better. However, the components thatyou have are always better than the mythically perfect, unobtainable components that you don't have.... One thing to note, though, is that Nelson Pass documented a kink in the transfer function of N-Channel IR parts that doesn't seem to happen in parts from other manufacturers. If I remember correctly, it doesn't happen with P-Channel parts, so you should be in the clear with the parts you have from either SEC or IR.
Irf9610 Lee35210 Pass Labs 4 10th March 2009 11:47 PM
discrete voltage regulators from different manufactures, are they all equal? KevinLee Parts 5 5th November 2008 12:44 PM
What output and driver transistors are the high-end manufactures using Sigurd Ruschkow Solid State 20 29th March 2005 07:41 AM
Tube Manufactures Cross references Trout Tubes / Valves 4 30th December 2004 05:23 AM
help matching irfp240 and irf9610 MikeZ Pass Labs 5 19th January 2003 11:19 PM
Page generated in 0.08452 seconds (74.70% PHP - 25.30% MySQL) with 10 queries
