Hi everibody!
I`m hapy today. Finished my aleph 2 monos. Thanks N.P. MarkFinis, Wayn S. and GRollins. Specialy Mark for beeng ease on me and my never ending questions. Amps works exelent. All values in limits. Bias 2.7 - 2.8A. Hot but not criticaly to 65°C. (BTW - my input fets (to-220 heatsiks) including Q1A5 are extremly hot - cant touch - Voltage over Zener folow.Q3 is 9,5 (9V nominal) voltage on the source of dif.input pair litle low(3.5V) -NORMAL?).Picture of front: Sory about pour quality! rgds Marjan |
#2 |
Picture of inside
#3 |
picture of back side
good luck all of you |
#4 |
Hello,
I like your design. Very clear. Will you engrave the front plate, like mefinnis? What are you using for top cover of your enclosures ? Regards, Kristijan Kljucaric http://web.vip.hr/pcb-design.vip |
#5 |
Hello Marjan!
Very nice design. Are you use the original PS capacitance? Which heatsink are you use? (model) BR, Milan |
#6 |
Hi Kristjan!
I`m glad you like it. General data about chasis. Front plate 10mm balck anodized AL, cover plate same as front, heat sinks 200x300mm per side 40mm fins on 10mm base plate from MALI ELEKTRONIKA in Slovenija, bothom and back - 2mm cooper plate painted black, toroid coverd front and top sided with cooper plate. Dim. 300x300x220mm weight 25kg/piec. rgds Marijan |
#7 |
Milan Hi!
132 000uF per chanal. Samxon from China. Standard quality low price. I`m aware that I`ll have to change them in a fev years, but I wanted to be shure first that I`ll be able to implement N.P. desigen properly. Allways time for tuning. rgds Marijan |
#8 |
diyAudio Moderator Emeritus
Super job Marijan,
You should be very proud. Do they sound as good as they look? Enviously, Rodd Yamashita |
#9 |
Hi Rodd!
If I say that I`m enjojying everi note coming from my Manepan`s fided bay the amps, and asuming that sound will get improuved by time (only 20 ours till now) I said all. But if I try to submit - bass tight fast and dynamic going so low as Planars alowing, mids are cristaly clear and (not just a phrase) full of ambient details, higs open but newer anoing. You shoud heer the brass section on Hose Alberto CD. Pure salsa. Stage is width, deep and high compared iven with HQ tube gear. Beautiful. There is no field in frequency scale coming out. Linear and natural. rgds Marijan |
#10 |
Somewhere in the past there was a thread expressing disappointment at not being able to find "quality" cases ......... ahem
![]() very nice! mark |
| pictures | 60 | Everything Else | 1 | 27th September 2007 01:09 AM |
| Aleph P1.7 first pictures | acaudio | Pass Labs | 63 | 21st February 2006 09:40 PM |
| Aleph Mini Pictures....Finally! | highbias | Pass Labs | 16 | 2nd September 2004 03:49 AM |
| Looking for aleph project pictures. | Andrej | Introductions | 6 | 1st March 2003 04:16 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 08:55 AM |
| Page generated in 0.09561 seconds (77.92% PHP - 22.08% MySQL) with 11 queries |
