Old 27th December 2004, 03:47 PM   #1
Send a message via AIM to xenofex Send a message via Yahoo to xenofex
Default Substitute FET IRF610 for balanced Zen line Stage
I'm considering building point-to-point wiring Balanced Zen line stage. My questions is anyone have the experience of substitute the FET's (IRF610). I have a loads of match IRFPE 30 and plan to use them for this project but not sure if this will degrade the sound quality?
As always, your opinion would be much valued. thanks
Old 28th December 2004, 03:11 AM   #2
U have trouble getting IRF610 in M'sia?
U can also use IRF510, or even IRF620. They shd also provide good performance.
Old 28th December 2004, 06:20 PM   #3
Thanks for the Respond. Actually I don't have any trouble getting IRF610. What really worries me is that capacitance of the input/output MOSFETs (IRFPE30) are very high. Can any one tell what could possibly go wrong using this device?
Capacitance IRF610 IRFPE30
Input (Ciss) 140 1300 Vgs @ 0V
Output (Coss) 53 310 Vgs @ 25V
Reverse transfer (Crss) 15 190 @ 1MHz
Old 29th December 2004, 07:23 AM   #4
You are right, the higher capacitances of the IRFPE30 compared to the IRF610 can cause degradation of the performance. Mainly the upper cutoff frequency will be affected, it will be lowered by some amount. And nonlinearities maybe increased, i.e. THD figures, because the MOSFET capacitances are nonlinear and the higher values may have stronger impact. The IRFPE30 devices are intended for power application, the IRF610 for low to medium power.
So, of course you can try using the IRFP30 devices keeping in mind that there will be some effect. If you are satisfied with the performance of your amp then keep them.
Godd luck and success with your line stage.
Old 29th December 2004, 01:55 PM   #5
Thanks!!
Old 1st January 2005, 07:22 PM   #6
liberty is offline liberty  Italy
Try also P3NB90FP.
It sound better than IRF610, but I don't know why.
Balanced Line Stage tonistefanovski Pass Labs 1 27th December 2005 09:25 AM
Balanced Zen v5 + balanced Zen line stage Adrie Pass Labs 0 30th May 2004 05:27 PM
All BJT balanced line stage Faber Pass Labs 4 10th February 2003 06:45 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
balanced zen line stage supernet Pass Labs 3 13th December 2001 06:10 PM
Page generated in 0.08087 seconds (75.29% PHP - 24.71% MySQL) with 10 queries
