I have just finished stuffing and soldering my Aleph-X boards (Hifizen Vintage). I have just bought an untrasonic cleaner to clean the flux and rosin off a board when I finish it. I plan to use plain old Alcohol (98% water free) to do the cleaning. Will the Alcohol damage the electrolytics in any way? Should I use a different cleaner instead of alcohol? How long should they go into the ultrasonic cleaner? Thanks in advance for any advice you can give me.
----------------------------------------------- Kilowattski |
#2 |
bump
#3 |
I soak a brush in methanol and clean the PCB. I rinse with methanol and let the thing dry or use a hairdryer. If well done, you get a shiny PCB and no harm is done to components whatsoever. I’m doing this for more then twenty years now and this simple method never let me down.
Hope this helps. /Hugo |
#4 |
I use contact cleaner called "Kontakt 61".
After that I spray some special lacquer (for pcb use) on the board. This makes a fine finish and kind of seal. Uli ![]()
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#5 |
I assume you mean "Kontakt 60"?
I have to try that one of these days. Never thought that would work. Thanks for the tip. /Hugo |
#6 |
Hi Hugo,
there are 2 versions K60 and K61. one is contact fluid the other one is to wash the contacts. AFAIK either is ok for this method. You have to wip it away before applying the lacquer. I once tried it when I worked for Sony being tired to throw boards into that ultrasonic bath. It turned out that this method is very reliable. None of several hundreds of boards (TFT control electronics) came back. Uli
#7 |
Interesting, didn't know about the K61.
I went to my bench and found "Kontakt WL" perhaps another variant of what you have but also marked as contact washer. /Hugo |
#8 |
Yeah, the K WL is a contact cleaner (to wash) but
if I remember correctly there are isolation issues with the WL. Another alternative is the "Kontakt Gold K 2000" if its available anymore. Just a bit expensive though. Uli ![]() edit: found the K 61 at RS comp Belgium Part# 233-828 The K61 cleans and does impregnate the board, the K60 and the WL only clean up.
#9 |
At the end of this thread we will be able to make a top ten of perfectly working cleaners who are not designed to clean PCB's.
/Hugo |
#10 |
You are right
Seldom things are used for the application the designer thought of... Uli
| L/R Boards and Matched IRFP240 Boards for Aleph/ A-X | lgreen | Swap Meet | 7 | 25th August 2009 04:56 AM |
| Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips | analog_sa | Swap Meet | 4 | 14th March 2009 05:29 PM |
| Cleaning circuit boards | jrv1965 | Everything Else | 6 | 20th February 2006 07:28 AM |
| Aleph2 Boards spring cleaning | harvardian | Swap Meet | 4 | 14th April 2003 01:13 AM |
| Can I use Brian GT's Aleph boards for a Aleph 1.2 | raincheck | Pass Labs | 2 | 27th May 2002 02:21 PM |
| Page generated in 0.09774 seconds (78.64% PHP - 21.36% MySQL) with 11 queries |
