#21 | |
maybe i donīt understand your question. Ground: both channels have separate ground. powersupply too. The controlboard too. The volume control relay shared a 12VDC supply and are switched to Control-gnd via transistors, see pic. Left and right channel are not an common ground. As i buy an second transformer, are both channels fully separate. All pcbs are made with Ground plane at bottom. Maybe is it not a best? But singlesided layout with a straight star ground wirng is not so easy... This should be realise by next project (AX) greetings Adam |
#22 |
Okay, I just didn't see where there was a ground anywhere. I always thought there needed to be a star washer type ground.
C |
#23 | |
#24 |
Hallo Adam,
nice work !!! I also plan to build an Aleph P. Which type of MOSFET's you have used in your design ? The original types are not available at my favorite dealer (Reichelt). Regards Ralph |
#25 | |
Reichelt is too my favorite. I used IRF510 (SEC) and IRF9610 (Fairchild) both from Reichelt.I bought 50+50 piece , selected these from equally lot and matched in pair to 1mV. See my matching-circuit. At Reichelt you canīt buy a original sealed tube from producer, only mix. But you can buy more and send what you donīt need back. thx Adam |
#26 |
Hallo Adam,
I take a look at the datasheets of the 610 and 9610 at International Rectifier and I think about giving the 630 and 9630 a chance. They have nearly the same data's, but the Rds_on of the 630/9630 are a little bit lower. These MOSFET's are available at Reichelt. Greetings from Titz Ralph |
#27 |
I wouldnt use the 630/9630. In a preamp the Rdson is of no
importance and as these Mosfets are primarily designed as switches they dont perform too well in an analog circuit. You may read some of the background literature by NP as well as the construction articles about A75 by NP and Norm Thagard. Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#28 | |
Have a look at the in-/out capacitance: IRF610 140/53pF IRF510 180/81pF IRF630 800/240pF /Adam |
#29 |
Thanks Adam & Uli,
I only take a look at the current and the channel resistance, but forgot the capacitance. I will look a second time and also read the articels. Regards Ralph |
#30 |
Hello,
I followed your tips and bought IRF610 / IRF9610 (50 pieces each) at Conrad Elektronik. A little bit more expensive than my prefered supplier Reichelt, but I get the "original" from International Rectifier. In the next step I have to select the right MOSFET's for my Aleph P. Which MOSFET should be equal ? I think the two upper current source transistors, the two lower current source transistors and the two amplifier transistors in the middle should have the same values, so that both sides of the preamp are identical. Regards Ralph |
| pictures | 60 | Everything Else | 1 | 27th September 2007 01:09 AM |
| Aleph Mini Pictures....Finally! | highbias | Pass Labs | 16 | 2nd September 2004 03:49 AM |
| Looking for aleph project pictures. | Andrej | Introductions | 6 | 1st March 2003 04:16 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 08:55 AM |
| Pictures of my Aleph 2 | marjan | Pass Labs | 31 | 31st July 2002 11:33 AM |
| Page generated in 0.15325 seconds (65.01% PHP - 34.99% MySQL) with 11 queries |
