#11 |
the relay volume control like aleph p1.0 (with adc0804) works. Problem: between step 32 (relay 1-5 on, relay 6 off) and 33 (relay 6 on, 1-5 off) gives it pop noise. Only with signal. anybody an idea? thx adam |
#12 |
You have already found the reason for the problem:
This happens when all te relays are switching at once - this generates a very short "level step". One proven method to get rid of that requires the presence of a "mute relay" on the output and some additional circuitry (microcontroller to be preferred): just switch the mute relay on just before the volume control makes "the evil step". If you play a little with the delay times, you might get this solution working without audible effects. |
#13 |
Hello Holger,
thanks for your replay. How is your new LP? I would like to do this without microcontroller. I have already by parallel connection of a 1k resistor at the exit of the circuit a clear improvement reached. The gain is a little lower, but it works good. I like this Aleph sound, i have today removed the input capacitor from the power amp , it sounds very good with much more detail and dry bass... Now i need a housing. greetings Adam |
#14 |
I uploaded the layout an my website.
For first the pre- and supply pcb. http://www.acaudio.de/aleph_p17_supply_bottom.pdf http://www.acaudio.de/aleph_p17_supply_top.pdf http://www.acaudio.de/aleph_p17_bottom http://www.acaudio.de/aleph_p17_top.pdf http://www.acaudio.de/aleph_p17_overview.pdf http://www.acaudio.de/aleph_p17_supply_overview.pdf Critical comments are welcome. thx Adam |
#15 |
Great looking AP!
Btw - the "bottom" (3rd one) pdf is not working (at least in my case How exactely did you do your PCB?? Are they milled? Btw - your amplifier - how hot does it get - and do you find the copper plates with transistors mounted on it as a good solution or not?? |
#16 | |
Official Court Jester
that will give ya small delay mebbe it will work
my Papa is smarter than your Nelson ! tnx to |
#17 | |
http://www.acaudio.de/aleph_p17_bottom.pdf /Adam |
#18 | |
The photoplots are printed on transparece paper with laser printer. Exposed with UV light and developed with NaOH. Pcbs is normally atched at 50°C witch sodium-per-sulfate .Then drilled and afterwards still times full-laminar exposed and developed with NaOH. For last soldermask painted (Contact). The Fets runs hot, aprox. 70°C without heatsinking, 65° with. With copperplate these are optimal thermal coupled. A simple thermal coupling in pair isn´t available then this layout is nearly point-symmetric, so are all coupled, both channels an one copper plate. and this looks pretty. I like copper then this is nearly double thermal conductive as aluminium. sorry for my bad english /adam |
#19 | ||
Danke Holger! Quote:
I added a 1µ capacitor at basis, and this works pretty. The resistor parallel to output is now removed. thx Adam |
#20 |
Where is the universal ground? Doesn't the circuit need a ground?
Nice looking setup. C |
| pictures | 60 | Everything Else | 1 | 27th September 2007 01:09 AM |
| Aleph Mini Pictures....Finally! | highbias | Pass Labs | 16 | 2nd September 2004 03:49 AM |
| Looking for aleph project pictures. | Andrej | Introductions | 6 | 1st March 2003 04:16 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 08:55 AM |
| Pictures of my Aleph 2 | marjan | Pass Labs | 31 | 31st July 2002 11:33 AM |
| Page generated in 0.29629 seconds (35.06% PHP - 64.94% MySQL) with 11 queries |
