Old 29th July 2001, 02:42 PM   #11
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Lightbulb Replacing non-polarized...
A traditional method of avoiding expencive nonpolarized caps in small signal circuits have been to use two electrolytics and connecting them together + to + , possibly also with a high value resistor ( 1oK ++ ) to the appropriate supply to keep the polarization... There is no logical reason for not connecting the negative poles and biasing to ground in a SE circuit....I have not been working on SE power amps since my very young days, and have not tested this on a modern SE power amp...might be worth trying, as one of the main arguments against ellytics in signal paths have been the lack of proper polarization....the idea is free for testing, I have no operational circuit readily available to test it myself...????
Old 30th July 2001, 10:08 AM   #12
From the price they must be metallised polypropylene, but for what it is worth try http://www.maplin.co.uk/mainframe.asp
Product code search for TX84F.
Cheers, Jake
[whoops, didn't see before posting that the 4500uf mentioned was the total value of two coupling caps, nothing there for 2200uf. Only a 4700uf cap at the url. In fact I'm wondering if they aren't really electrolytics in the wrong section of the catalogue]
[Edited by Jakeh on 07-30-2001 at 12:44 PM]
Choice of OTL output capacitors pftrvlr Tubes / Valves 3 16th May 2012 10:47 PM
taking out Output coupling capacitors in a dac lightmaster Digital Source 12 17th April 2006 09:10 PM
Output capacitors -=Zepplock=- Solid State 19 11th March 2005 04:31 PM
Capacitors in output? Lisandro_P Solid State 10 15th June 2001 09:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 20.00%)
Copyright ©1999-2013 diyAudio
