#11 |
Update: Heatsink grounding and instability - lessons learned...
Here's what I did - its behaviour is now impecable 1) Grounded the heatsink direct to (well - 15mm away) the star earth point (my electronics are sitting slap in the middle of the heatsink). Dispensed with previous h/s grounding scheme. 2) Added (across the supply) a 2.2uF polyester and a 47uF electrolytic hard up against the gain stage electronics as local HF PSU decoupling. 3) Added a 220ohm gate resistor to the gain MOSFET soldered direct to the MOSFET gate terminal. Thanks for the help Pete |
| Naim NAP250 Regulator Instability Problem | ceharden | Solid State | 9 | 29th April 2008 09:22 PM |
| Bias instability in Heathkit W-5M amp | ltarini | Tubes / Valves | 2 | 27th September 2007 03:02 PM |
| EL-34 instability in EICO HF-35 amp | ltarini | Tubes / Valves | 0 | 26th September 2007 05:43 PM |
| Help! Phono stage LF instability | Jeb-D. | Tubes / Valves | 2 | 25th August 2007 09:39 PM |
| Output stage instability | Katapum | Solid State | 35 | 27th December 2005 04:31 PM |
