Aleph X CRC Power Supply for 60 W amp
Old 18th December 2004, 10:16 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default Aleph X CRC Power Supply for 60 W amp
I'm trying to build an Aleph X, about 60 Watts or slightly less, biased at 50% with 8 IRFP044 per channel. I'd like feedback on how to do this, from those that have done it already. Anyway, what do you think of this CRC power supply that I have simulated?
How many volts will I need at the PS output? Anyone else make a similar supply? I am not building a CLC as I have no source for the L.
Old 19th December 2004, 12:58 AM   #2
jrsun is offline jrsun  United States
John,
yours is similiar to mine, 4 x 68000uf + 2 x 4.7 uf + 0.22ohm x 2 per channel but 2 bridges. 28v unloaded and 24.5 loaded.
Old 19th December 2004, 01:08 AM   #3
kilowattski is offline kilowattski  United States
kilowattski's Avatar
Get the AXE-1 spreadsheet from the Aleph X Builders thread to calculate the rail voltages you need.
Kilowattski
Old 19th December 2004, 01:52 AM   #4
MikeW is offline MikeW  United States
MikeW's Avatar
Default 18-20 volts
Depending on the bias and the load 18 to 20 volts at the rail. Is this per mono block? How many VA transformer? Make sure the resisters will have some air flow and handle the wattage. The AX I built was a small stereo with 16.5 volt rails. It had a 15-0-15 VAC output 600 VA transformer. It was drawing 6-8 amps out of each rail depending on how hot I wanted to run it.
MikeW
Aleph X CRC Power Supply for 60 W ampHide this!Advertise here!
Aleph 5 Power Supply martinschki Pass Labs 68 8th October 2016 05:08 AM
Aleph 30 power supply jmmartins Pass Labs 2 28th September 2007 05:47 PM
aleph 1.7 power supply jarthel Pass Labs 8 29th June 2007 05:20 PM
Aleph X power supply Mach_Y Pass Labs 42 29th March 2004 09:43 PM
Aleph-4 Power Supply needs help ruangrit Pass Labs 1 25th January 2004 06:38 AM
Copyright ©1999-2017 diyAudio
