#11 | |
The gain of the BOSOZ , and every differential pair IMHO , does not depend from the quality of the "tail current sources" . That current sources can be passive (resistors ) or active (Constant CS) and the gain of the circuit still depends by the load resistors (or CCS or Variable CCS) and by the resistor value that join the "tails". |
#12 | |
Account Disabled
In addition, let me have a physical experiment with two pipes each having length of 20cm, diameter of 1 cm and a 0.5cm-dia hole in the middle. Pipe 1: The upper end of the pipe is open. The lower end is closed with a resistance material (tail registers). The middle hole is also closed with another resistance material (output potentiometer). Pipe 2: The upper end of the pipe is open. The lower end is also open (CCS). The middle hole is closed with resistance material (output potentiometer). Now, I put my mouth to the upper end and blow the pipes. Pipe 1: Part of the air will escape through the middle hole. The amount will be depending on the relative resistances between the output potentiometer and the tail registers. Pipe 2: Once the middle hole has resistance, high or low, the most air will escape through the lower end opening. If I replace the air with electrons, I might have to suck the pipe, not blow. I see the difference in this way between register tails and CCS tails, with the output potentiometer. Don't you think so? Merry X-mas !!! |
#13 | |
seriously your description apply better for a CMRR ( common mode rejection ratio ) explanation IMHO in a case of a single ended input . But how with R5? ( see previous attachment) If you short it, the tails will be in parallel ; and how if you use a resistor(R3) and a CCS(R4) at the same time? Cheers and marry X-mas to all! |
#14 | |
Account Disabled
Your circuit shows local part only. Anyhow, your amp gain is decided with the drain error voltage and the gate error voltage. By a mathematical approximation, it is expressed as (R1+R2)/R5. The drain error voltage depends on the amount of current flowing through R1 and R2. Now, let’s see the global picture. Some of AC current flowing across R1 and R2 would leak through the output caps and again through the potentiometers (let’s say, R6 and R7, probably of low values). Then, the above mathematical approximation will be getting more erroneous. This could be prevented by replacing the R3 and R4 with active CCS. As mentioned before, the original article of SOBOZ having resister current sources says: “Lower values of output potentiometers will reduce the gain of the circuit …” Do you think the writer is D&D? Let’s think about a little bit more. The sex, rock&roll would become more exciting… ![]() Seasons Greeting !!! Cheers !!! |
#15 | ||
![]() Quote:
-I know well that if I use a pot of 10k the gain will be higher that with one of 5k . I am just thinking that the gain will stay the same using or not a CCS in the lower part ( sources ) of the circuit, taper included . ( someone often said that the differential pair is happy also driving a short ). If you have to have a load ( the pot , say 470ohm) , from my approximated point of view, the total circuit gain at the output will remain the same and independent from the use (or not ) of the CCS ( at the sources of the signal FET) I know that the CCS provide a better conversion from a single ended to a balanced signal where one of the gates of the differential pair is at ground . I experienced no differences in gain with the D1 cascode stage with or without CCS: the signal from the DAC is connected directly to the source of the "pipe" , its gate is at a virtual ground ; Drain is loaded with a resistor . ![]()
#16 |
Account Disabled
Wow. Snow field? I'm missing skiing.
Alright, thanks, discussion seems to be enough. I will make the potentiometer as I think about, when I return back from the trip to S'pore. By the way, guys from S'pore, could you direct me where in S'gapore I can do window shopping of the elecronic components?
#17 |
Account Disabled
I’m unsure whether the title of the thread was correct or not in technical term. It might, however, don’t matter if the content has something.
I received the 4 x 11 steps rotary switches from a Norwegian friend and built up the potentiometer as shown in post#1. Some of resister values were changed due to availability in the shops nearby where I stay. Particularly, the shunt resister value was changed from 10 to 22 ohms. They were Taiwan-made metallic 1/4W 1% class. During fabrication, I found my hands were getting tough in soldering the small dots. The finish was ended up in rather ugly shape. My BOSOZ (with CCS tails) is for unbalanced input and balanced output. The + input side was used to receive the input signal and had the volume potentiometer while the – input side was connected to the ground. I thought that this arrangement was the noise source to the speakers. I wanted to remove the noise so that I wanted to replace the unbalanced input potentiometer with a new balanced output potentiometer, wishing improvement in CMRR. At the same time, I wanted to taste a new exploration, by making what I never done before. And, this guided me to the thinking of the post#1. I replaced the new potentiometer last night. I was excited about the result. With no signal input, I turned up the volume knob step by step, bringing my curious ears to the 1cm distance from my 4ohms 90dB speakers. Until I reached to the top volume, the speakers were virtually dead quite. I wondered something must have been wrong. I decided to test music, and put one CD wandering around like a homeless dog. No music, wait a moment, it was because the knob position was at the start point. I stepped up the knob one click. Yeah! The music started at low level. Finally, I listened to the whole music loudly at the various volume positions. Wow! It worked. I felt that the overall sound got better, particularly in high frequencies. I was wondering whether this could be due to the reduced noise level. And, it was right that the amp gain was resulted in reduction (I have no calculation). Anyhow, I got full satisfaction with the result. I felt that the overall music sounded more relaxed with better distinguished small details. I will see how long I will live with this new potentiometer. If I see any room for further improvement with my BOSOZ, I will not hesitate to make it. Somewhat late though, Happy New Year!!!
#18 |
Account Disabled
Here is my final setting.
Works very fine for me. In addition to this, the input volume and amp gain level coordinate together. Hope this will be a useful info. |
#19 | |
you can shop for electronic components in Sim Lim Tower and Sim Lim Square in Singapore. regards, tony Quote:
#20 |
Account Disabled
Thank you very much, Tonywong !!!
| Double variable outputs for BOSOZ | gchrist | Pass Labs | 10 | 20th January 2008 04:38 PM |
| Simulating variable output impedance | abzug | Solid State | 3 | 30th December 2007 07:47 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 04:15 PM |
| First Watt-ish Chip Amp, Variable Impedance | tgorham3 | Chip Amps | 3 | 13th February 2005 06:27 PM |
| BoSoZ stepped attenuator | cjunk | Pass Labs | 47 | 12th December 2002 08:59 PM |
| Page generated in 0.15326 seconds (85.26% PHP - 14.74% MySQL) with 11 queries |
