It was going to be an Aleph 3, but it ended up with 17.5 volt rails.
MikeW |
#2 |
Thanks to Nelson, Jam and George for the extra parts.
MikeW |
#3 |
Fairchild output devices, 350VA victoria magnetics 15-0-15 , 36000 uf. , .2ohm, 36000 uf. per rail. It sounds very nice. Bias 1 amp per output.
MikeW |
#4 |
no flash
MikeW |
#5 |
Nice job Mike,
What speakers are they driving? You should try to make some slightly better pictures and send them over to PassDiy. /Hugo |
#6 |
Lightning In A Bottle
Very nice! I like your wood front panel...warm, reddish tone. Warms up the usually cold-looking (but warm to the touch) metal chassis
#7 |
Nice Aleph Mike!
Is it made on MiniA boards or ?? |
#8 |
Looks like the heatsinks are taken from the old Heathkit amp that dates from the 70's; same ones I used on my Zen4. Mine work great on the Zen; how do they do on your Aleph ?
#9 |
I gave away all my mini boards. If eveyone I sent them to builds an amp you should see quite a few. Someone was nice enough to send me a set of Brian GT boards.
I am driving some little Cambridge soundworks speakers along with mini-pipe-o. The heatsinks are only 40 deg. This amp will see more work before I am finished with it. I built five Mini-A's and kept the one I liked the best. Some Aleph P's next and maybe a PLH after that.
MikeW |
#10 |
What type of wood/finish did you use?
Would a woodchuck bother to chuck MDF? |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.08646 seconds (78.99% PHP - 21.01% MySQL) with 11 queries |
