I have started my next quest. And it shall be the Aleph 2.
I have blagged some heatsinks fro old radio transmitters approx 4 if need be but I would like to use 2 . They measure 40.5cm x 9.5cm x 12 cm the are bigger in places . I have included a link to some pictures. They are pretty big and chunky . I hink there is enough surface area to fit 12 mosfets on but I will have to custom build the boards they go on. I would be interested knowing peoples opinion as wether they are fit for an aleph 2 . regards dave http://www.geocities.com/dhole23/heatsink001.jpg http://www.geocities.com/dhole23/heatsink002.jpg http://www.geocities.com/dhole23/heatsink003.jpg http://www.geocities.com/dhole23/heatsink004.jpg http://www.geocities.com/dhole23/heatsink005.jpg http://www.geocities.com/dhole23/heatsink006.jpg http://www.geocities.com/dhole23/heatsink007.jpg http://www.geocities.com/dhole23/heatsink008.jpg |
#2 |
Thermal Resistance = SQRT(50 / A) Where A is the total surface area in cm².
#3 |
Maybe Aleph 5's
MikeW |
#4 |
thanks for the.............. short replies. I guess I could have done some measurements before asking. I have now got the heatsink xls file that was posted and will atempt to use this to calculate something. If I post htese results perhaps people could advise some more.
regards dave |
#5 |
I have the following information from the heatsink xls. Can anyone advise as to how this translates into usefull information on determining how many of these heatsinks I would need to use per monoblock of 100w aleph 2 ....pls
Thermal Ratings Per Fin 6.1824 deg C / Watt H/S Body 14.4668 deg C / W Total 0.3027 deg C / Watt |
#6 |
Multiply the heat in watts the Aleph 2 produces by 0.3, then add something like 24 for the room temerature and you will have the temperature of the heatsink.
#7 |
cheers
I am busy now searching for the "aleph 2 temperature" Anyone know ? I ambusy searching a million posts as we speak. dave |
#8 |
doh as in 300 watt idling ?....
#9 |
If I understand correctly - you would like to use 2 heatsinks/channel - so you have 150W dissipation on each HS - so 150W * 0,3K/W = 45K -- and after adding average room temp of 25°C - you get 70°C on heatsinks ...
#10 |
at first glance they look a little small to me...
but pictures make everything look small. at the least you would want to use two per channel. |
| FS: Heatsinks for Aleph(s).. | skaara | Swap Meet | 2 | 29th August 2006 10:36 AM |
| Heatsinks for Aleph 5 | tobias_svensk | Pass Labs | 2 | 15th February 2004 04:08 AM |
| Heatsinks - Aleph 5 | ElectroNick | Pass Labs | 7 | 13th December 2002 08:55 PM |
| Heatsinks for Aleph | skaara | Pass Labs | 8 | 16th September 2002 07:30 AM |
| heatsinks for aleph 2. | BrianGT | Pass Labs | 12 | 12th March 2002 06:59 PM |
| Page generated in 0.10246 seconds (76.59% PHP - 23.41% MySQL) with 10 queries |
