Remove resistence to A75 for unbalanced use?
Old 5th December 2004, 11:24 AM   #1
Danyele82 is offline Danyele82  Italy
Default Remove resistence to A75 for unbalanced use?
To A75 amplifier for unbalanced use I can remove R28 , R5.
R29 and R2 can be romoved?
Old 5th December 2004, 12:52 PM   #2
look here the circuit A75
Old 5th December 2004, 01:52 PM   #3
Alain Dupont is offline Alain Dupont  France
Alain Dupont's Avatar
Danyele82,
Yes, you can...
Well, I don't think so.
For the cost of 4 resistors, 2 XLR's and 2 switches, it's a shame to
remove the Balanced inputs of the A75.!! Who knows, you'll probably
build a balanced preamp sooner or later...
PS: Now with my CCS-X-Bosoz preamp I use my A75 balanced, and I prefer this type of connections, the balanced mode has great advantages...
And using Belden 89207 twinaxial cable, its not so costly to have balanced cables..
Alain.
Old 6th December 2004, 01:47 PM   #4
For unbalanced use the gain is determinated by (R81 + R3//R27)/(R2//R29)?
If it's right the input resistence (R4) can be eliminated (or it's necessary for the low-pass with C1)?.
The quality of C7 and C5,C6 are important to the final result?
Old 6th December 2004, 11:57 PM   #5
Danyele82,
>> If it's right the input resistence (R4) can be eliminated (or it's necessary >> for the low-pass with C1)?.
Keep R4, it wont interfere in the 75 K Ohms unbalanced impedance,
but globaly there must be symetry between positive and negative input's.
Norman Thagard and Nelson Pass tells: the only requirement being that corresponding values on the positive and negative input networks be matched.
For the quality of C3,4,7 4.7uF, 16V, electrolytic
C5,6 220uF, 16V, electrolytic
I have used Panasonics, quite standard types...
Regards.
Alain.
Remove resistence to A75 for unbalanced use?Hide this!Advertise here!
NHT ST-4 how to remove tweeter ? Chilli6565 Multi-Way 0 22nd September 2008 05:35 AM
Trying to remove RF jduffy Chip Amps 8 26th February 2007 12:36 PM
How to remove hum sound? Kimhua Solid State 7 5th July 2003 04:56 PM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 07:54 PM
Copyright ©1999-2017 diyAudio
