Hello all:
Well, i have a problem with an Aleph5 pcb (kristian's pcb)... when i power it up, only 3 output mosfets (T6, T7, T8) get hot I have replaced the mpsa18 and all the irfp240, but no luck. Any idea of what is happening, guys?? Thanks in advance!! PD: Sorry about my english skill !
#2 |
I suppose the current source fets are getting hot? Do you know how much current is flowing? Measure the voltage over the source resistors. If this is the normal 0,5-0,7volts then you somehow shorted the active current source to ground but at least the current source is working. Measure the resistance after the source resistors to ground. If this is lower than 5k something is wrong! Can you tell us the output voltage (DC)? Check the wiring of the output boards. Hope this helps, William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#3 |
Thanks a lot for your help wuffwaff.
I've touched the source current fets, and only 2 of them were warm (less than 50șC), so i decided to check them using the voltimeter diode test-range. At least they were not short-circuited. Anyway, I replaced them, and the result is that no one of the irfp240 are getting hot anymore When i was measuring the other parameters, i have accidentally short-circuited some components of the pcb , and now i am waiting for the replacement parts so in 3 or 4 days i'll be working again on the amp... Ximo |
| Another Aleph5 | mefinnis | Pass Labs | 57 | 2nd June 2005 01:10 PM |
| Yep, another Aleph5 | rwagter | Pass Labs | 19 | 31st May 2003 08:06 PM |
| my aleph5 ... | sernikus | Pass Labs | 13 | 21st June 2002 10:15 AM |
| Aleph5 PSU | scrazy | Pass Labs | 2 | 30th November 2001 10:58 AM |
| Which one (A75, Aleph5..) ? | tom | Pass Labs | 2 | 26th November 2001 11:26 PM |
| Page generated in 0.06278 seconds (74.19% PHP - 25.81% MySQL) with 10 queries |
