Old 18th May 2005, 08:35 PM   #21
MikeW is offline MikeW  United States
MikeW's Avatar
I have built both. They are both very smooth sounding amps. I could never get the DOZ to sound as good as the Zen. I took apart the DOZ for parts and gave the Zen away.
I still have my Aleph.
MikeW
Old 19th May 2005, 05:01 AM   #22
Account Disabled
Drinking coffee and reading the thread...
I learned lot through Pass Zen series about the value of simplicity and about the value of one electron. I think most of us are staying at this corner to share these things, not to simply hunt the world top amp, or not to simply inform that mine is better or the best. If you really would like to inform place B is better than place A, please go to the place B and say so loudly. Then clever people would find and go to that place. I would like to see them soonest possible...
jH
Old 8th January 2006, 06:44 PM   #23
mohan72 is offline mohan72  India
I have built the JLH 15W as well as the DoZ. Both have similar topologies. The DoZ is nowhere near the JLH. It seemed very lifeless.
I have not heard the Zen. So if you want to build the DoZ, you might as well build the JLH. You can easily adapt the DoZ PCB to model a JLH amp.
Mohan
Old 23rd September 2008, 03:37 PM   #24
destroyer X's Avatar
Default I have decided to try, once again, the DOZ from Rodd Elliot pages
I found it reasonable... do not think this one sounds better than a good class AB amplifier... i felt it lifeless...... also too much hot to produce only 10 watts (single ended).
Distortion is low...but quality is not something very special.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 23rd September 2008, 03:40 PM   #25
Default Too much heat inside my room...it seems a television receiver switched on
No good to Brazil temperature.... also spend a lot of wasted energy.
Here is the picture.
Carlos
Old 23rd September 2008, 03:42 PM   #26
Default And this heatsink result deceptive to me... only 56 watts
And the unit is very hot.... you cannot hold for more than 5 seconds... having the risk to have your finger attached to the heatsink smelling Dx barbecue.
Carlos
Old 23rd September 2008, 03:45 PM   #27
Default Well, this morning i have decided to listen something class A
And i did it....but really i felt some other simple amplifier outperforms this one.
Not confortable the temperature...not a very good sound too.
Just good....or sligtly better than reasonable.
I have made it to PNP transistors.. this was the modification done...the rest was to follow the instructions.... the transistors used were TIP42 (not too fast) and output J4215 from Fairchild.
My Dx Amplifier smashes this one... easy... rolling into the floor and laughing.
regards,
Carlos
Old 23rd September 2008, 03:58 PM   #28
Default Here you have a recording uploaded to the Youtube
Music was recorded alive.... band over an enormous truck surrounded by speakers....but showing you some local music.... quality is not so good because the music.
Latter i will produce better recording and will upload to Youtube.
http://www.youtube.com/watch?v=HNmkulHurt4
Carlos
Old 23rd September 2008, 04:09 PM   #29
Default Sorry folks.... i was thinking this was the DOZ from Solid State
I made the mistake to enter this data here.
Sorry boys... this was to be posted at Solid State.
Carlos
Old 16th September 2009, 08:59 PM   #30
shaan is offline shaan  India
shaan's Avatar
I found out that-
1. The DoZ preamp is a Gem!
2. The DoZ amp is no good!
3. The Zen is way better than DoZ!
4. The MOSFET Follower by PMA is way better than both Zen and DoZ, but by no means the best!
Combine 1 and 4 and see(listen) the difference youself.
LESS "THINGS", MORE LIFE
DOZ - Death of ZEN amp from Rod Elliot hifimaker Pass Labs 26 6th April 2012 05:09 PM
The death of Hi-Fi SunRa Everything Else 9 16th October 2008 03:22 AM
Death Magnetic ak_47_boy Music 6 14th October 2008 01:12 PM
Death Of Zen DoomPixie Solid State 2 22nd August 2006 10:21 PM
DEATH by UPS exurbia Planars & Exotics 10 4th June 2006 11:29 AM
Page generated in 0.10733 seconds (79.43% PHP - 20.57% MySQL) with 11 queries
