Hello,
I have hardwired a pair of Aleph 5 boards and the output offset voltages are well, 53mV and 62mV, voltage across source resistors are 0.6v, voltage across zener Z5 is 9.5v. But the voltage across transistors Q4 and Q5 are 6.5v. Has anyone encountered such a problem before and would this cause a problem for the amplifier. I have varied the value of the R17 (4k7) resistor but it only reduces the voltage across the transistors by 0.5v. Thanks for any help rendered Chua |
#2 |
The one and only
Which are Q4 and Q5 in your schematic? Are they the NPN
transistors? |
#3 |
Hi
Yes they are the NPN transistors on the schematic. |
#4 |
The one and only
This implies a Vgs on the output devices of 5.9 Volts which
seems a bit high. What type of outputs are you using, how many, and what value Source resistors? |
#5 |
I'm using source resistors of 1Ohm. Running at from a bench supply of +/-20v. I'm using total 4 MOSFETS (Infineon MOSFETS)
here's the datasheet. http://www.infineon.com/cmc_upload/d...20N60CFDv1.pdf Incidentally, the Vgs averaged out around 5.20 for these devices. Just out of curiousity, having used matched differential input pairs (IRF9610), i couldnt quite get the DC offset below 100mV. Temperature of course plays a big role. But would swopping and changing 9610s until i get an offset as low as possible be a good method of reducing offset? Even though the Vgs of the input differential pair wont be matched anymore. |
#6 |
I think your best bet would be to try to get the Vgs on the output mosfets matched.
#7 |
It maybe possible to 'quasi' match the existing MOSFETS in the circuit by placing some resistance from either the gate-to-Source or from the drain-to-Source of the output MOSFET pins. The idea of putting resistance from the drain-to-Source, however doesn't seem very practical in an output stage.
Perhaps Mr. Pass can advise us if this is or isn't reasonable solution? |
#8 | |
The one and only
Are you actually using 10 ohms in the amp? I see not. I looked up the Mosfets, and they do indeed run about 6 volts Vgs. No reason why it won't work, but you should increase the resistor off the drain of Q1 (the left handed input transistor) to compensate and have equal current sharing on the input diff pair.
#9 |
Thank you for the help. I will re-insert the matched pairs, and use a pot trimmer in place of the resistor in the Drain of the input differential pair Q1 and trim it until the dc offset voltage is ideal.
Once again, many thanks! |
#10 |
New update, I have replaced the matched input differential pair and inserted a pot trimmer in place of the resistor at the Drain of Q1.
I have adjusted the trimmer to give nearly 10mV offset. Give and take due to temperature. But there is a difference in the trimmer values when i measured them, one is 235 Ohms, and the other is 535 Ohms. Should this be a concern or should I call it a day and be grateful there was no magic smoke |
| two transistors voltage regulator using IRFBC30 | chungtat | Solid State | 2 | 13th February 2006 08:33 AM |
| high voltage transistors | bocka | Solid State | 2 | 21st October 2005 07:29 AM |
| High voltage output amp(with NPN transistors) | Gunders | Solid State | 9 | 17th March 2004 12:19 PM |
| TO-3 transistors and high voltage DC | ih | Solid State | 7 | 16th January 2002 11:36 AM |
| Page generated in 0.10342 seconds (83.75% PHP - 16.25% MySQL) with 10 queries |
