Working on a ALEPH-X project, a version originated from
Grey, has three MOS power instead one on each side, top and botom. Grey kindly reminded the importance of the match, bottom half, and nicer for the top pairs too. If the circuit (one channel) is divided into four areas:top left; right, botom left;right. The best I can get from the 1% 0.5W dale R60C/D is listed ascendingly from R1 to R12 (see botom). I am thinking group R4 to R9 to the botom, R4,5,6 assigned to the (3 parallel bias resistors) botom left , R7,8,9 to the botom right. Then, choose R1,2,3 for the top left, R10,11,12 for the top right. My reasoning: closer match for the botom L & R, closer match for the top and botom. Is this arrangement proper? I use the same approach for the output resistors ( o.47 ohm, 3-5W). R1 220.48 R2 220.49 R3 220.49 R4 220.53 R5 220.55 R6 220.56 R7 220.61 R8 220.68 R9 220.68 R10 220.70 R11 220.70 R12 220.75 fjc
#2 | |
/Hugo |
#3 |
the exact value!
In real life its not possible to get a perfect match, as every mosfet is unique in his behaviour. taking any 1% resistor will work fine. Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#4 |
Seems you are talking about the resistors on the gates of the FETs. IMHO, they don't need any matching at all.
UrSv Those who say it can't be done should not stop those who are doing it. |
#5 |
as long as you are using 1% resistors you don´t have to match them. It is only of some importance when using 5% or 10% resistors like the MCP71.
It is of more importance that the fets where the sence resistor is connected are really well matched. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#6 |
"It is of more importance that the fets where the sence resistor is connected are really well matched"
Please advise the location of the sense resistors. In Grey's diagram for example, thanks. FET has been measured and match with the Vgs. thank you, everyone, fjc |
#7 |
The sensing resistor is the source/ output resistor, just fond the definition, it was matched before matching the bias R, thanks for the reminding,
cheers, fjc |
| dayton wright st300a matching / bias trnsformer unit | krmaudio | Planars & Exotics | 14 | 21st October 2010 12:05 AM |
| Aleph Ono and FET matching | rsbay | Pass Labs | 4 | 10th November 2005 03:37 PM |
| Matching Aleph-X | anders.a | Pass Labs | 10 | 2nd May 2005 04:02 AM |
| power fets, bias, gain matching & other stuff. | lowlevel | Solid State | 11 | 22nd January 2005 05:03 PM |
| Matching MOSFET for Zen V4/Aleph 5 ??? | PsykoK | Pass Labs | 5 | 26th September 2002 09:04 PM |
| Page generated in 0.08905 seconds (83.39% PHP - 16.61% MySQL) with 10 queries |
