Old 19th July 2002, 11:35 PM   #11
promitheus's Avatar
Thanks,
so you mean this is a model for each half ?
I will try to put it in. I hope it works. I am kinda of new to this program.
Old 19th July 2002, 11:44 PM   #12
Yes, it is a model for each half of the 2sk389.
Old 20th July 2002, 12:04 AM   #13
promitheus's Avatar
SO I think the model is ok. I used most of the Data for the model you gave me. Some where not used because they were not in the list I filled out.
But the main characteristics from the model where there.
Thanks a lot again.
Old 21st July 2002, 01:49 PM   #14
promitheus's Avatar
I did some simulations on the circuit but the bandwidth was dissapointing. the high end roll off started above 20 KHz.
I am not sure if the jFET model is correct or not. I will check this again.
What do your simulations show ?
Old 21st July 2002, 02:24 PM   #15
I have compiled my results.
You could play with C1, but with a cost.
Old 21st July 2002, 03:45 PM   #16
tvi is offline tvi  Australia
tvi's Avatar
Found this the other day, from l'Audiophie magazine and uses the input stage fom the Le Monstre power amp.
<font color=#808040>Fig 17: Filtre actif 2 voies utilisant deux filtres passifs RC en cassade. Caracteristiques des composants: resistance a 1% tantale, condensateurs cuivre, potentiometres a film plastique, trim 100<FONT FACE="Symbol">W</FONT> &lt;&lt;COSMOS &gt;&gt;, La frequence de compure est aisement determinee a partir de F<sub>c</sub> = 1 / 2 <FONT FACE="Symbol">p</FONT> RC Ainsi pour une coupre de 590Hz C= 10nF R = 27k<FONT FACE="Symbol">W</FONT>.</font>
Old 21st July 2002, 03:49 PM   #17
promitheus's Avatar
those look like cascaded FET buffers.
Where was it used for?
Old 21st July 2002, 04:44 PM   #18
tvi's Avatar
Found it posted at <a href="http://forums.delphiforums.com/n/main.asp?webtag=haute_fidelite&nav=start">le Forum de HAUTE-FIDELITE.net</a>, can't find the thread now.
The original poster said;
<i>"I do not know if it is Kaneda, it is the active filter of the audiophile N°7, new series. With the PSU of Kaneda 50W and the input stage of the Monster 8W for each of 4 cells"</i>
Tanslated the caption for the schematic using <a href="http://trans.voila.fr/?getting_web">Viola
</a><i>Fig 17: active Filter 2 ways using two passive filters RC there cassade. Caracteristiques constituents(component): copper resistance is 1 % tantale, condensers, potentiometres has plastic film, trim 100<FONT FACE="Symbol">W</FONT> < < COSMOS > >, The frequence of compure is aisement determinee has to leave Fc = 1 /(2 <FONT FACE="Symbol">p</FONT> RC) So for a coupre of 590Hz C = 10nF R = 27k<FONT FACE="Symbol">W</FONT></i>.
Thought someone might find it of interest?
James
Old 22nd July 2002, 01:29 AM   #19
promitheus's Avatar
tvi would you be interested in making a new thread and designing an all SMD discrete opamp for general use like active crossovers, phono stages, analog DAC outputs and so on ?
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
About a discrete active crossover gaetan8888 Multi-Way 9 12th September 2007 06:30 PM
Passive-Active I/V stage Relaxin Digital Source 16 17th April 2007 09:04 AM
Active XOVER....OPAMP or discrete....??? Lyra Multi-Way 8 23rd March 2007 12:19 AM
Active crossover & buffer stage for a 5 channel amp sunil Chip Amps 9 15th December 2004 07:10 AM
Page generated in 0.09695 seconds (86.28% PHP - 13.72% MySQL) with 11 queries
