turned on Aleph 1.2,but LED doesn't Light up
Old 22nd November 2004, 03:50 PM   #1
Steve Fay is offline Steve Fay  United States
Default turned on Aleph 1.2,but LED doesn't Light up
Hi, late last night I got to the point where I could turn on for the first time my Aleph 1.2,when I did the LED's didn't light up? Is it possilbe they're wired wrong (+,-). I'm using BrianGT first run of boards and there is a + and - on the board but when it came to the LED itself I had to guess at the polarity. Does it make a difference?
Steve
Steve F
Old 22nd November 2004, 04:40 PM   #2
dantwomey is offline dantwomey  Canada
To the best of my knowledge the anode is (+) and the cathode is (-). On new LEDs just out of the package one lead is longer than the other. The longest one is the anode.
Dan
Old 22nd November 2004, 05:04 PM   #3
Blues is offline Blues  United States
Blues's Avatar
You can test your LED by setting ohm meter to the right ohm range (x10 I think) and placing +lead to anode and -lead to cathode (forward biasing it). Or you can get it to light up with a flashlight battery.
Old 22nd November 2004, 05:14 PM   #4
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Default Re: turned on Aleph 1.2,but LED doesn't Light up
Yes it does.
Dan
Correct.
- Dan
Old 22nd November 2004, 06:38 PM   #5
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The Blue Silicon Carbide types are static sensitive and
can be blown out fairly easily.
Old 22nd November 2004, 07:14 PM   #6
Thank you for the quick repelies. The one thing that really through me was that both leads were the same lenght ??? I 'll probley just replace it and may be try a different style.
Steve
Steve F
Old 22nd November 2004, 10:36 PM   #7
GRollins is offline GRollins  United States
I didn't see that you had tried the LED the other way. Just reverse the leads. Chances are fair that the LED is still okay, after all, it's a diode and current doesn't flow if you hook it up the wrong way. I just did it Saturday.
Grey
Old 23rd November 2004, 12:02 AM   #8
Oil is offline Oil  United Kingdom
looking from the top of an LED, the leg nearest the flat edge is the negative
Old 23rd November 2004, 12:24 AM   #9
zygibajt is offline zygibajt  Poland
Does the amp at least work ??
Old 23rd November 2004, 02:05 PM   #10
Thank very much. I swictched the legs around and it worked. Yes the amp works. I've got a groung loop hummmmmm, but I think I know what I did wrong in the amp..? Did I mention how wonderful it sounds. It blows away my Hafler 9500 which is a very good (border line great ) amp.THANK YOU NELSON. One amp compleled (almost, still some metal finishing ete..) and the the half of a speaker,I listen for over two hours even the wife came in and listen. It was that good.
Thank you again
Steve
Steve F
turned on Aleph 1.2,but LED doesn't Light upHide this!Advertise here!
hum on pre-amp when volume is turned up phrarod Tubes / Valves 6 14th June 2009 07:11 PM
Pop when amp is turned off boostin1989 Solid State 6 10th October 2006 05:10 PM
Leach amp has hum only when turned off! kiwi_abroad Solid State 12 26th March 2004 04:17 PM
Hum when volume is turned down miguel2 Tubes / Valves 34 18th March 2003 07:51 PM
