turned on Aleph 1.2,but LED doesn't Light up
Old 24th November 2004, 03:31 AM   #11
GRollins is offline GRollins  United States
Honestly, I've got a bunch of mongrel LEDs that I've picked up here and there. Quite a few of them have leads nearly if not identical in length. Life's too short to go fiddling with them. Stick 'em in one way. If they work, great, if they don't, turn 'em around. The one this weekend actually had leads of differing length and I had it right the first time, then tore the circuit down and rebuilt it (power supply for amplifer) slightly differently with the LED in backwards. Cussed and put it in the other way. Worked.
Cussin' is a great way to communicate to a device that it's not doing what you wanted it to do.
Note that I didn't say that the device actually responds to said cuss words, but neither do they respond to polite parlor talk so you might as well cut loose and have fun.
Grey
Old 24th November 2004, 07:41 AM   #12
Cr3ator is offline Cr3ator  Netherlands
Lightbulb Transparancy is the word!
Most of the times you can see trough the LED and see a difference in the inside between both leads. I belive it was the anode that had a small element inside the led and the cathode a large element. Anyway, once you know this for one LED, it will be the same for the others
For me this works best.
Erik - still working on his Aleph 5 - Hoogma
Old 24th November 2004, 06:10 PM   #13
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Grey,
using cuss words on a blue led while make it glow red
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 27th November 2004, 10:37 AM   #14
There is an expression here: "to cuss a blue streak" With that in mind, I suspect that if I cuss enough a red LED might turn blue. Given that red ones are cheaper than blue, perhaps I might be onto a money saving measure.
Grey
turned on Aleph 1.2,but LED doesn't Light upHide this!Advertise here!
hum on pre-amp when volume is turned up phrarod Tubes / Valves 6 14th June 2009 06:11 PM
Pop when amp is turned off boostin1989 Solid State 6 10th October 2006 04:10 PM
Leach amp has hum only when turned off! kiwi_abroad Solid State 12 26th March 2004 03:17 PM
Hum when volume is turned down miguel2 Tubes / Valves 34 18th March 2003 06:51 PM
Copyright ©1999-2017 diyAudio
