Old 20th November 2004, 01:40 PM   #1
wuffer is offline wuffer  Denmark
Default 4 sk 102 heatsinks. what amp can it be used for??
i have 4 SK 102 heatsinks
the height is 100mm
http://www.schuro.de/Daten/Fischer/SK47.pdf
is there any amp i could bould.. i havde the aleph p 1.7 preamp and i was thinking of yet an aleph
can it be done???
Old 20th November 2004, 02:02 PM   #2
Stabist is offline Stabist  Slovenia
Stabist's Avatar
at 100mm height - the factor is 0,4K/W - so I would take 2 and 2 heatsinks per each channel - if you want to stay on the very "safe" side - A3 is the choice - you'll have 20°C rise above ambient temp - with A5 that goes to 30°C ... Still very very OK!
The only thing is that the chassis will be very wide and depth - but quite low ... But personnaly - I like that ...
Old 20th November 2004, 02:12 PM   #3
thats nice.. i would look at the a5...
Old 21st November 2004, 09:53 PM   #4
uli is offline uli  Austria
Default caution
if you mount 2 of these heatsinks in close proximity and thermally coupled (like making an amp side of 430mm length) the thermal resistance is not reduced in a linear manner. this means that you won´t achieve 0.2 K/W in this case, but rather 0.27 K/W - 0.3 K/W because the 2 heatsinks heat each other.
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 22nd November 2004, 06:03 AM   #5
thats not good.. right??
what is the best way to do it if i should use thise heatsinks???
Old 22nd November 2004, 06:07 AM   #6
Default aleph design
put the heatsinks on 4 sides, or build an Aleph 3 - you will be on the safe side(25-30° above ambient temperature)
Uli
Old 22nd November 2004, 06:13 AM   #7
what if i make 2 mono blocks??? strange looking amp then i guess..
Old 22nd November 2004, 06:18 AM   #8
Default that would be fine!
Uli
Old 22nd November 2004, 06:20 AM   #9
then i would go to the drawing board...
tanks
Old 22nd November 2004, 06:42 AM   #10
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Default Re: caution
If you look at the graph for this sinkprofile your story is correct if both heatsinks are placed on top of eachother, that's when 0.27 to 0.30 applies.
Heatsinks act like chimneys, place two next to eachother and each retains its function.
More important with Class A amplifiers is to put the heatsinks well above floorlevel so that cool air may flow to the bottom of the heatsink, warm and rise.
If placed parallel to eachother there is the effect of cross influence but with minimal effect.
Put a vertical plate to the open flange side of the heatsink and the thermal factor would be reduced to a significantly lower level than 0.20 at 100 mill (creating a true chimney).
A heatsink like that is extremely costly in production, therefore only done on special order.
Some manufacturers get around that problem by placing the heatsink in a duct, for example take a look at the Vincent SP991.
An idea for the true DIY'r, build a heatsink from 1/2 inch thick alloy plates, tapped and bolted together, with thermal grease at the joints. A heatsink shaped to favor, with excellent cooling ability, and a base plate of more favorable thickness for cooling high bias demands than regular alloy heatsinks.
The really cheeky use copper plates.
Looks like Sponge Bob has killed another thread.
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 04:33 PM
about heatsinks bigpanda Solid State 2 4th May 2005 03:34 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
Heatsinks Peter Daniel Swap Meet 19 3rd February 2004 11:08 PM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 09:23 PM
Page generated in 0.10536 seconds (77.21% PHP - 22.79% MySQL) with 11 queries
