I can obtain the IRFZ44 for A$3.00 (possibly less in quantity) whereas the IRFP044 is $7.85 in small quantities.
The IRFZ44 seems to be pretty much the same device in a better package TO-247 instead of TO220. Key spec.s are as follows: IRFP044 / IRFZ44 VDSS = 60V (same) RDS(on) = 0.28 (same) ID = 57 / 50A Power Dis. 180 / 150W Thermal Res. - Case to Sink: 0.24 / 0.5 C/W gfs: 17 / 15S td(on): 19 / 14ns td(off): 55 / 45ns Ciss: 2500 / 1900pF Any views on this and are there any other critical specifications to consider? Nix |
#2 |
#3 |
Warp Engineer
On Holiday
Use the IRFP044's... You'll probably find it works out cheaper to import these devices from arrow or digikey in america.
#4 |
Minor correction to above
"The IRFZ44 seems to be pretty much the same device in a better package TO-247 instead of TO220." should read: "The IRFZ44 seems to be pretty much the same device except that the IRFP044 has a better package (TO-247) and hence higher power rating than the IRFZ44 (TO220 package). OTOH the IRFZ44 is slightly faster." I appreciate the advice above - but can anyone tell me why the IRFP044 is preferred (given the power of either is ample) - what other specs are important when choosing a MOSFET? Nix |
#5 |
Warp Engineer
On Holiday
VDSS = 60V .... rail to rail voltage should be less than this
RDS(on) = 0.28 (same) .... meaningless when building analogue amplifiers ID = 57 / 50A .... high is better Power Dis. 180 / 150W .... this is a function of die size and hence also Ciss as well as package type .... for a given power rating for the amp output stage we try to minimize total culmative Ciss Thermal Res. - Case to Sink: 0.24 / 0.5 C/W .... you'll be able to run the bias high with the 044's for a given Junction temp gfs: 17 / 15S .... higher transconductance is preferred td(on): 19 / 14ns .... Assuming we set the XA to 50% and operate it below cutoff which is what we normally do then the mosfets dont turn on or off at any time during the waveform. td(off): 55 / 45ns .... same as for td(on) Ciss: 2500 / 1900pF .... determines the number of devices that can be placed in parallelled for a given high frequency rolloff. Hope all that helps. |
#6 |
AudioFreak
Thanks for the detailed reply - I understand all your points. What other specs are important? I also emailed you re your matched IRFP240 sale. Nic |
#7 |
The one and only
I haven't tried the Z44, so I couldn't say, but the
higher transcondctance and current rating is going to make for a slightly different sound. Like the IRF150 or 250, it will probably tend to have better performance on the bottom, but may be a bit darker on the top. You might like this better, maybe not. Try it. |
| IRFZ44's in orion 250 | SS64 | Car Audio | 10 | 1st May 2009 12:12 AM |
| 2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? | jarthel | Parts | 12 | 26th July 2007 09:08 AM |
| irfz44 | rodolfo | Solid State | 9 | 18th April 2005 07:31 AM |
| Best place to place bleeder resistor in a power supply? | G | Tubes / Valves | 13 | 4th August 2004 09:26 AM |
| Aleph With IRFZ44 | Jay | Pass Labs | 7 | 24th February 2003 09:59 AM |
| Page generated in 0.08755 seconds (74.58% PHP - 25.42% MySQL) with 10 queries |
