The parts list shows R1, C14, C16 as "User Value". I cannot find any mention of these parts in the manual or on the schematic. What do these parts do and how do I go about choosing values for them?
Also, in addition to the Vishay resistors, I noticed Mouser also sells Wima caps. Has anyone tried using Wima instead of Panasonic for the film caps?
Gregorio |
#2 |
I guess you ran into the same problem i did when ordering parts
this week. DigiKey is out of the .15uF panasonics. Looks like they won't be getting them in until mid-December. I couldn't find a Wima part at .15uF on Mouser... but then again i might have missed it - difficult to read online guide. I have substituted a higher voltage Panasonic cap while i'm building and have the Pearl on the bench, and will replace it when the other part becomes available. If someone can give part #'s and a place to buy the Wima's i'd give them a try too. m. |
#3 |
Vince Harris |
#4 | |
It is not sure you need to install those. You can find lots of info about this here: http://www.passlabs.com/downloads.htm Look for the ONO literature. Mr. Pass is such a kind man Steen. |
#5 |
I need to reduce the gain of the Pearl phono stage. I would like to switch to a higher output cartridge. I follow the Pearl with a line stage that has a minimum gain of 7dB because of the output transformer. I am using this in a calibrated (0VU = 7cm/sec stereo) lacquer cutting setup. So far I have been unable to get a pad to work without increased distortion.
Besides designing a correct output pad is there a way to reduce the gain by 12dB or so? |
| MC Stage for Pearl Phono | Panelhead | Pass Labs | 7 | 6th November 2005 12:30 AM |
| Pearl Phono stage | dhole | Pass Labs | 4 | 29th July 2004 04:15 PM |
| MC Stage for Pearl phono | Panelhead | Pass Labs | 7 | 31st October 2003 09:16 AM |
| Pearl Phono Stage | macka | Pass Labs | 10 | 28th August 2003 09:31 PM |
| Pearl Phono Stage Boards | macka | Pass Labs | 8 | 26th April 2002 04:08 PM |
| Page generated in 0.08728 seconds (73.23% PHP - 26.77% MySQL) with 10 queries |
