Hi out there!
I wonder if anyone of you out there can help me out with a problem…. I am the happy owner of a Bride of Zen. I based it on a pcb from AudioXpress, and fitted it out with premium components. Basically It sounds great…. But I have a problem with an ”non-audible” noise or distortion that gives a very annoing listening fatigueness. Some facts that might be usefull: The torroidal - housed separately - is somewhat smaller than recommended: 28-0-28V/80VA giving the circuit some 64V AC. The Rectifiers (D1-D4) are 25BYV79E-200. Coupling capacitors (C103 & C104) are Auricaps. The amp drives my headphones – Grado SR-80 – directly, accept for a 1Kohm resistor between C103 and the headphone outlet. A big thank you in advance…. Plydsen |
#2 |
DIY !
Trafos are ok, I guess
Try different caps! Arne K
Ars longa, vita brevis |
#3 |
With a standard line-level source (like CD) my BOZ also distorted. I have put a extra series resistor on the input (I used a 5K output attenuator).
Nelson suggests using 2 pots, one to set the level on the input and one as output volume control. Also some people have changed the gain of the circuit. Do a search on this board, there a couple of threads about the subject. |
#4 |
Plydsen.
how big are those output caps? When you are driving a low impedance they should be big enough otherwise you´ll have a nice highpass. You could try a combination of 220uF / 50V Panasonic FC plus 10nF as recomended by Klaus. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#5 |
Hi!
I had same problem with my BoZ ... I've tried with different input resistors - no help ... The solution was to lower CDP's output (it has variable output - but it lowers also the resoulution...) So - as someone said - you can use another pot at input ... Mine solution was an AlephL ... No probelms whatsoever since I use it ... |
#6 |
The one and only
It's very common for the input to the preamp to be overloaded
by the source. Try attenuating it with a pot of resistive divider. |
#7 |
Heureca….
My signal is pure as newfallen snow….. This afternoon I changed my couplingcaps without getting rid of the problem. Then I put 2x 2K2 Ohm cermet trimmerpots at the pcb entrance - adjustet it to 1K5 Ohm and the problem was gone. May I express my gratitude Arne K, WuffWaff, Taco, Stabist and Mr. Pass – with guys like you its easy to be a D.I.Y. newbee… Regards, Plydsen |
| What are you listening to? | MikeW | Pass Labs | 36 | 20th June 2011 01:54 AM |
| Recommended listening on the net | stoolpigeon | Music | 8 | 28th August 2007 02:01 PM |
| F1, F2, F3 listening impression | Nicola | Pass Labs | 37 | 10th August 2007 07:22 PM |
| UvA listening experiment | Rhinobirds | Digital Source | 0 | 17th June 2005 09:46 AM |
| Page generated in 0.08846 seconds (80.99% PHP - 19.01% MySQL) with 10 queries |
