Hi All
My First time in hear I am thinking of building the bride of Zen single stage pre amp my first go at this I would very much like some advise on Parts Selection regarding capacitors @ volume Pot Questions 1, Can you suggest Good capacitors for C1, 3, 4, 101,102 can I use a higher voltage than the specified 100 volts if necessary pending on availability.0f the 100volt Transformer 300v 30+30volts as I have this one in my part box 2, what is the best value I can use for dual gang volume pot if I can’t find the recommended 5KOhms, that is easy to source something like the Alps or better pleas give pot value I don’t have one of Mr Pass’s Amps as whet so a suggestion or two hear would be nice Some thing around 30 Watts into a 6 Ohm load Cheap @ easy to build Thank you for the help Chaps Regards Colin
Colin The Blues Man |
#2 |
Banned
i used WIMA MKS and MKP for caps, instead of pot i made an aleh - p style relay volume control, description you find on the page linked with the www button below.
#3 |
I would choose Aleph3 - 30W/8R and 60W/4R ...
I also done sound comparison between Zen v4 and A5 (both diy projects) - I like Aleph's sound more ... Instead of BoZ - why not decide for AlephL? |
#4 |
Stabist: why you prefer the Aleph 3 that the Aleph 30 ????
#5 |
Hi Stagiest
I am looking for easy to build Zen or Aleph the aleph3 is just a though at the moment I find it confused with all these versions of amp which ever one I choose will have to go no the back burner for now As starting easy with bride of Zen pre amp but still looking for good 1000uf 100volt caps for it Just found these Caps can some one recomend the best one of these http://uk.farnell.com/jsp/endecaSear...306241,3198583 Colin
#6 | |
I never said I prefer A3 more than A30. I just said that if I would be again at my first Pass based project - I would choose for A3 today and not for Zen v4... Power dissipation is very similar - so chassis must be pretty much the same - and that's expensive part. Trannie is the same for both - 400-500VA and ~2x18V secondaries ... OK, there is a slightest difference to buy few more transistors for A3 and few capacitors ... But I prefer Aleph sound more ... OK regarding A30 - it's more like A5 if you ask me - so you need some more $$ to finish it up ... |
#7 | |
I also like the "matching" between A5 and AL more than with A5/BoZ combination ... And again - trannie specs are same in both cases ... You need chassis on both cases; if you decide so make a PCB - it's similar sized in both cases ... I don't think AL costs much much more ... |
| parts wanted | tonysherwin | Swap Meet | 0 | 5th April 2008 11:34 AM |
| Wanted: subwoofer parts. | Spasticteapot | Swap Meet | 4 | 13th November 2006 02:46 AM |
| WANTED: LCD projector parts! | ForGreatJustice | Swap Meet | 6 | 19th December 2005 08:23 PM |
| Help wanted on getting parts from the US | bigparsnip | Swap Meet | 16 | 23rd September 2003 03:19 PM |
| Page generated in 0.46473 seconds (18.83% PHP - 81.17% MySQL) with 11 queries |
