My Aleph5 clone working!
Old 16th July 2001, 07:38 PM   #11
scrazy is offline scrazy  Taiwan
I get these heatsinks from heatsink factory(In Taiwan).
They build & sale all kinds of heatsinks I think....
The smallest ex:for TO-220.
The largest ex:for cooling some machine...
But for DIYer the price is too high,because of the quantity.
But this is my only way to get these big guys building my Class A amplifier...!
Old 17th July 2001, 06:50 AM   #12
Pete Fleming is offline Pete Fleming  Australia
Default Capacitor
Jam, I believe the value you suggest may be too large for noise suppression. While under ideal circumstances it won't make any difference, one may be tempted to use an electolytic capacitor for that value. Electros provide quite poor performance at high frequencies and I would suggest a lower value capacitor with better HF characteristics would be better.
Pete
Old 17th July 2001, 01:56 PM   #13
jam is offline jam  United States
jam's Avatar
Default Taming Zener Noise.
Pete,
I should have have mentioned that the capacitors I would use are Black Gates or Os-Cons. I have also used tantalums to good effect. All these capacitors have excellent high frequency characteristics.
If the thought of an electrolytic bothers you a .47uf or 1uf film and foil capacitor works just as well. I arrived at the above values after a lot of experimentation. Too small a value will not work as well as the noise is pretty broadband.
Before you add the capacitor you have to set the zener current, too low a value and the noise will be a lot higher. Then consider replaceing the resistor that feeds the zener with a another current source (a current diode works well here), which will further reduce the noise and improve the current sources rejection of rail (power supply)noise.
Jam
P.S. By the way, how is your pre-amp project doing?
Old 17th July 2001, 09:35 PM   #14
hifi is offline hifi  Sweden
do you hear any AC humm through it or is it silent??
Old 18th July 2001, 02:47 AM   #15
Jam, Just got back from Singapore a few moments ago so no advancement on the pre-amp this week
I notice a parcel is waiting for me to collect so hopefully the boards have finally arrived so I can continue with it.
Pete
Old 18th July 2001, 03:33 AM   #16
When I am very close to the bass driver,there are some hums, no hiss..
This is acceptalbe,but I think it can improvement...
questions:
Now my aleph configuration :
Each channel using two big Capacitors & one transformer.
and the GND of each channel is seperate and NOT attach to the amp case.
1.Should I connect TWO channel with TWO GND point(why?)?
2.Should I make a chasis GND to reduce the noise(why?)?
3.Any comment for reduce the little hum?(all that just because my poor layout skill?)
thanks all
Old 18th July 2001, 03:39 AM   #17
jam's Avatar
Hifi,
It is pretty quiet. Also I should note that some zeners are noiser than others, and if you decide not to use a capacitor you should select one that is less noisy (1/2 watt zeners seem to be less noisy).
You could stack a few led's togther in place of a zener and this would be quieter (you would have to change the current source resistor as the voltage drop would be different).
Jam
Old 18th July 2001, 11:24 PM   #18
i think the problem in my amp is my trafo...cus if i move the speaker wires around the hum increases...and decreases...but i will try with a cap across the zener....
/micke
Old 19th July 2001, 07:52 PM   #19
promitheus is offline promitheus  Europe
promitheus's Avatar
http://members.tripod.de/Promitheus/ground_amp.htm
read here a few ideas about grounding amps maybe you can find something that can help you improve your hum.
Ilias
My Aleph5 clone working!Hide this!Advertise here!
Anyone working/interested on/in Aurum Cantus Volla clone? Franklin Multi-Way 0 19th August 2005 01:53 PM
Another Aleph5 mefinnis Pass Labs 57 2nd June 2005 02:10 PM
Yep, another Aleph5 rwagter Pass Labs 19 31st May 2003 09:06 PM
HELP .... Aleph5 mefinnis Pass Labs 17 10th March 2003 06:32 AM
my aleph5 ... sernikus Pass Labs 13 21st June 2002 11:15 AM
Copyright ©1999-2017 diyAudio
