Old 9th July 2002, 06:53 PM   #1
dshortt9's Avatar
Default Aleph 2 with 60V rails.
Assuming I have enough heatsink, can I run an Aleph 2 with 55-60V rails? The reason is I bought 43V 1.5kw toroids at a cheap price. If not what values should I change? I do not want to increase the 3A bias otherwise I'd use the Aleph 1.2 values.
Old 9th July 2002, 09:37 PM   #2
The one and only
Nelson Pass's Avatar
Sure. You have enough semis to handle the power, the
only issue is heat sinking. If you can, bias them a little
higher than stock, and you'll get more power and lower
distortion.
Old 9th July 2002, 10:17 PM   #3
dshortt9's Avatar
Thanks, Nelson. I have big heatsinks! No stinkin' calculation, just big. ( ~ 0.05 C/W )
Old 9th July 2002, 10:52 PM   #4
Other options include regulated rails or the possibility of using an inductor (or resistor) in the power supply filter. In between disasters here, I've been working on a regulator circuit for the Aleph-X. As of this afternoon, I believe I've got it where I want it and will commence artwork for a PC board. My Aleph-X will draw nearly 7A, so the regulator should also do quite nicely for my Aleph 2s (my rails are more along the lines of stock Alephs, but I biased them harder--about 3.3A).
Incidentally, a tip of the hat is in order to Paul (aka paulb) for graciously donating some P-ch MOSFETs to the cause. Thanks, man.
Depending on the impedance of your load--in this case, meaning high Z--having the extra voltage swing might even be a good thing. Conversely, if you're running a low impedance, you'll run into current limiting when the amp is delivering all the current it can manage.
Grey
Old 9th July 2002, 11:06 PM   #5
dshortt9's Avatar
Good ideas, a capacitance multiplier regulator would be a good idea. I plan on using an inductor for a pi filter. How did you tweak 3.3 amps out of the bias?
Old 10th July 2002, 01:07 AM   #6
Easy...stick a 100 or 250k pot in where R19 (Aleph 2 nomenclature) is. The more resistance, the more bias current. Note that it's a diminishing returns kind of thing--you won't get too much increase past about 200 to 250k in that position. If you need to do serious adjustment, start lowering the values of the Source resistors for the output MOSFETs.
Grey
Old 10th July 2002, 04:35 AM   #7
BDP is offline BDP  United States
Default Adjusting R19
I have read a number of postings on adjusting R19 to increase or decrease the bias of the current source and I understand that this would contribute to the base current of Q5 and thus the regulation of the current source devices. When R19 becomes so large as to not contribute any base current then all the contribution would be coming from the source resistor voltage which would be a maximum of Vbe or about .66 volts. Now here is the question I have and maybe I'am missing something but wouldnt you have to also increase the bias on the negative driver side also to keep the output offset to a minimum?.
I could see adjusting R19 for fine adjusting of the output offset to compensate for Vgs differences.
By the way here is a shamless plug of my Aleph. Building mono blocks with 35 volt rails and each mono block should be able to dissipate 200 watts. It won't be long before I will be able to answer my own question.
Old 10th July 2002, 05:33 AM   #8
dshortt9's Avatar
Someone correct me if I'm wrong but I think the DC negative feedback to the differential pair will cause the negative driver to be biased higher to compensate for the increased current draw by the current source, as the diff pair attempts to compensate for the DC offset at the output. The actual DC offset of the output may be more affected by the slight mismatch of the hopefully matched differential pair. OW! that hurt.
Old 10th July 2002, 11:04 AM   #9
wuffwaff's Avatar
BPD,
since the current must go somewhere the bias in the positive and negative side will be equal (no load attached). When not Nelson´s bolt of lightning will appear and destroy something very badly
DC offset is not affected by R19 in any way (not counting for effects by running cooler/hotter)
The only thing that could need some adjustment when raising the bias is the current limiter on the negative side. If not the amp will clip on negative inputs.
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 10th July 2002, 07:24 PM   #10
The one and only
If R19 open does not give enough bias, you can get more
bias by attaching R19 to a voltage divider between the
output and the negative rail and bootstrap the middle
junction to the output through a 220 uF cap. This causes
R19 to draw current out of the junction (Base of NPN
transistor) instead of feeding current in, and so the bias
goes up.
90+90 volt rails sakis Solid State 42 5th April 2011 01:38 PM
P3A on +/-12V rails 00940 Solid State 6 5th March 2008 12:44 PM
Rails voltages for A30 same Pass Labs 16 26th June 2007 07:14 PM
from +/-80v to +/-70v rails leander Solid State 14 13th September 2005 11:26 AM
Cap across rails? MikeW Pass Labs 12 24th August 2004 01:35 PM
Page generated in 0.26606 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
