#21 |
it would work. if the signal transistors can take the voltage. another thing is. do you need that voltage? it's just a waist without bias that is equal high
(if it's not a very high impedance). and then you need more outputs. in other words. you got a aleph1.2
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers Last edited by AudioSan; 31st January 2013 at 12:10 PM. |
#22 |
it would work , even without any change in circuit
I would increase few resistor values around small bjt in Aleph CCS , just for fun , but that will not influence operation in any way
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#23 |
ZM. yes, if bias is not raised
wich is useless not to do IF driving a 8ohm load![]() with bias at let say 4.2A, he may want some more outputs thats 0.7A pr fet with 6 outputs. 70V*0.7A=49W dissipation pr fet. thats a little over my comfort zone for the fets
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#24 |
so what - he's obviously member of FAB
#25 |
| 90+90 volt rails | sakis | Solid State | 42 | 5th April 2011 01:38 PM |
| P3A on +/-12V rails | 00940 | Solid State | 6 | 5th March 2008 12:44 PM |
| Rails voltages for A30 | same | Pass Labs | 16 | 26th June 2007 07:14 PM |
| from +/-80v to +/-70v rails | leander | Solid State | 14 | 13th September 2005 11:26 AM |
| Cap across rails? | MikeW | Pass Labs | 12 | 24th August 2004 01:35 PM |
